Mobile Home Skirting Replacement
    1. Mobile Home Skirting Replacement, Mobile Home Skirting: step 1, image 1 of 3 Mobile Home Skirting Replacement, Mobile Home Skirting: step 1, image 2 of 3 Mobile Home Skirting Replacement, Mobile Home Skirting: step 1, image 3 of 3
      • Find the missing pieces or order them from a Mobile Home supply company or Amazon, making sure they are the correct height.
      • Once you have the missing pieces, you can take each piece and start sliding them together as in Image 2.
      Ask FixBot
    2. Mobile Home Skirting Replacement: step 2, image 1 of 3 Mobile Home Skirting Replacement: step 2, image 2 of 3 Mobile Home Skirting Replacement: step 2, image 3 of 3
      • Start by sliding the pieces together (there are what looks like a curved piece on the end of each piece).
      • Once attached to each other, ensure the bottom is slid into the bottom track.
      Ask FixBot
    3. Mobile Home Skirting Replacement: step 3, image 1 of 3 Mobile Home Skirting Replacement: step 3, image 2 of 3 Mobile Home Skirting Replacement: step 3, image 3 of 3
      • Once the panels are secure in the bottom track, you will need to lift the upper track a little.
      • After lifting the upper track upward, you will slide the skirting in under it.
      • After pushing it into the upper track, you will hear a click and it should be secure in the top track.
      Ask FixBot
    4. Mobile Home Skirting Replacement: step 4, image 1 of 1
      • Once secured in the lower and upper tracks, attach it to the existing panel.
      Ask FixBot
    5. Mobile Home Skirting Replacement: step 5, image 1 of 1
      • You can secure the panels further by putting screws in the top of the panel if needed. This will help further in case of wind storms.
      Ask FixBot
2 other people completed this guide.
Attached Documents
0 Guide Comments
Past 24 Hours: 11
Past 7 Days: 48
Past 30 Days: 228
All Time: 5,431
