Mitsubishi WD57734 Lamp Replacement
Views: 2.7K
View statistics:
Past 24 Hours:
3
Past 7 Days:
16
Past 30 Days:
92
All Time:
2,726
Comments: 0
Go to guide comments
Completed: 0
Favorites: 4
4 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 15 minutes
Difficulty: Easy
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Introduction
Go to step 1 ↓
Accessing the lamp in this television is straightforward and requires minimal disassembly.
Tools
    1. Mitsubishi WD57734 Lamp Replacement, Lamp: step 1, image 1 of 1
      • Before disassembling your television, be sure it is powered off and unplugged.
      • Remove the single 18 mm Phillips #1 screw on the lamp access panel.
      Ask FixBot
    2. Mitsubishi WD57734 Lamp Replacement: step 2, image 1 of 1
      • Pull the lamp access panel off of the back panel of the television by pulling straight back on the left side of the panel near the screw then pulling to the left.
      Ask FixBot
    3. Mitsubishi WD57734 Lamp Replacement: step 3, image 1 of 1
      • Loosen the two Phillips #2 screws securing the lamp housing to the television until the screws will swivel vertically.
      • These two screws are permanently attached to the lamp housing and cannot be removed completely.
      Ask FixBot
    4. Mitsubishi WD57734 Lamp Replacement: step 4, image 1 of 1
      • Using the handle, pull the lamp housing straight back out of the television.
      • Do not touch the glass of the lamp with your bare hands. The oil from your fingers can distort the TV image and lead to other issues.
      Ask FixBot
Herman Chai
196 Reputation
3 Guides authored
Cal Poly, Team 18-39, Regan Fall 2012 Member of Cal Poly, Team 18-39, Regan Fall 2012
CPSU-REGAN-F12S18G39
4 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 16
Past 30 Days: 92
All Time: 2,726
