Mitsubishi T200 Screen Replacement
    1. Mitsubishi T200 Screen Replacement, Screen: step 1, image 1 of 2 Mitsubishi T200 Screen Replacement, Screen: step 1, image 2 of 2
      • Begin disassembling the phone by removing the phone back cover and battery.
      Ask FixBot
    2. Mitsubishi T200 Screen Replacement: step 2, image 1 of 1
      • To remove the back plate, loosen and remove the four screws by using a #00 Philips head screwdriver.
      Ask FixBot
    3. Mitsubishi T200 Screen Replacement: step 3, image 1 of 1
      • Separate the front plastic component from the motherboard component.
      Ask FixBot
    4. Mitsubishi T200 Screen Replacement: step 4, image 1 of 1
      • Take the circuit board off the motherboard.
      Ask FixBot
    5. Mitsubishi T200 Screen Replacement: step 5, image 1 of 2 Mitsubishi T200 Screen Replacement: step 5, image 2 of 2
      • Unclip the four clips to remove the screen (connected to the clear plastic) from the circuit board.
      Ask FixBot
    6. Mitsubishi T200 Screen Replacement: step 6, image 1 of 2 Mitsubishi T200 Screen Replacement: step 6, image 2 of 2
      • Remove the attached ribbon from the circuit board by prying open the gray plastic clip at the top right of the circuit board.
      Ask FixBot
    7. Mitsubishi T200 Screen Replacement: step 7, image 1 of 2 Mitsubishi T200 Screen Replacement: step 7, image 2 of 2
      • We can now insert the new screen and reassemble the device.
      • Place the ribbon of the new screen into the clip on the top right of the circuit board.
      Ask FixBot
    8. Mitsubishi T200 Screen Replacement: step 8, image 1 of 1
      • Clip the new screen onto the circuit board.
      Ask FixBot
    9. Mitsubishi T200 Screen Replacement: step 9, image 1 of 1
      • Replace circut board back on top of motherboard.
      Ask FixBot
    10. Mitsubishi T200 Screen Replacement: step 10, image 1 of 1
      • Take the entire internal assembly and join it with the front plastic housing.
      • Ensure that the tops of both pieces clip into place before joining the bottom ones.
      Ask FixBot
    11. Mitsubishi T200 Screen Replacement: step 11, image 1 of 1
      • Join the phone's face assembly to the back plastic housing. Make sure you carefully insert the front into the antenna's clip first.
      • Snap the whole unit together.
      Ask FixBot
    12. Mitsubishi T200 Screen Replacement: step 12, image 1 of 1
      • Firmly replace screws into the backing.
      Ask FixBot
Finish Line
2 other people completed this guide.
Taylor Lewis
20 Reputation
1 Guide authored
Ohio State, Team 1-5, Meza Spring 2014 Member of Ohio State, Team 1-5, Meza Spring 2014
OSU-MEZA-S14S1G5
4 Members
24 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 31
All Time: 1,333
