Mitsubishi Hands Free Module Firmware Update (MMCS NR-242)
  1. Mitsubishi Hands Free Module Firmware Update (MMCS NR-242), Enter the Service Menu (not W-15 & W-17): step 1, image 1 of 2 Mitsubishi Hands Free Module Firmware Update (MMCS NR-242), Enter the Service Menu (not W-15 & W-17): step 1, image 2 of 2
    • Enter the Service Menu by pressing and holding the SETTINGS and MAP-Buttons for 4 seconds.
    Ask FixBot
  2. Mitsubishi Hands Free Module Firmware Update (MMCS NR-242), Enter the Service Menu (W-15 & W-17): step 2, image 1 of 1
    • Enter the Service Menu by pressing and holding the INFO/SET and SEEK-Buttons for 4 seconds.
    Ask FixBot
  3. Mitsubishi Hands Free Module Firmware Update (MMCS NR-242), Navigate the Service Menu: step 3, image 1 of 2 Mitsubishi Hands Free Module Firmware Update (MMCS NR-242), Navigate the Service Menu: step 3, image 2 of 2
    • Press on Hands Free Module.
    • While the Hands Free Module is in diagnosis mode, the sound input to the microphone unit is output directly through the speaker.
    • Check the Parts Number.
    • We'll need this later when downloading the Firmware file.
    • Check the Version Number.
    • If the Version Number is 19.00.000 or 50.00.000 you already have the last available Firmware installed and don't need to do anything.
    Ask FixBot
  4. Mitsubishi Hands Free Module Firmware Update (MMCS NR-242), Download the Firmware: step 4, image 1 of 2 Mitsubishi Hands Free Module Firmware Update (MMCS NR-242), Download the Firmware: step 4, image 2 of 2
    Ask FixBot
  5. Mitsubishi Hands Free Module Firmware Update (MMCS NR-242), Move the File: step 5, image 1 of 1
    • The flash drive needs to be formatted to FAT32 and should not be larger than 16GB. Additionally the MMCS can be a bit picky and might not accept all flash drives. If it can't read your flash drive, just try a different one.
    • Copy the update.package file to the root directory of the USB flash drive.
    Ask FixBot
  6. Mitsubishi Hands Free Module Firmware Update (MMCS NR-242), Insert the flash drive: step 6, image 1 of 1
    • Insert the USB flash drive into one of the USB ports in your car.
    • You can usually find a USB port inside the center console or below the head unit.
    Ask FixBot
  7. Mitsubishi Hands Free Module Firmware Update (MMCS NR-242), Initiate the Update: step 7, image 1 of 1
    • Re-enter the Hands Free Module-Section of the Service Menu.
    • Press on the S/W Update-button.
    • If there is no S/W Update-button it means that the head unit didn't detect a valid file on the flash drive. This either means that you already have a version newer than the firmware file installed (as is the case for me), an incompatible firmware file, or that the system can't read the flash drive.
    Ask FixBot
  8. Mitsubishi Hands Free Module Firmware Update (MMCS NR-242), Enter the Security PIN: step 8, image 1 of 1
    • Enter your Security PIN.
    • If you don't have one set you can just enter 1234.
    • If you have forgotten you Security PIN, you can forcibly remove it by pressing the Unlock-Button in the Hands Free Module-Section of the Service Menu.
    Ask FixBot
  9. Mitsubishi Hands Free Module Firmware Update (MMCS NR-242), Wait: step 9, image 1 of 2 Mitsubishi Hands Free Module Firmware Update (MMCS NR-242), Wait: step 9, image 2 of 2
    • Wait for the update to finish. This may take some time, don't worry if the progress bar stays at 0% for some time.
    • Do not remove the flash drive or turn off the car while the update is running!
    • If the update fails and the warning message states that you should make sure that the USB port is properly powered, you can just reboot the head unit and try again.
    Ask FixBot
  10. Mitsubishi Hands Free Module Firmware Update (MMCS NR-242), Finish: step 10, image 1 of 1
    • Press OK to finish the update.
    Ask FixBot
Drive safe!
5 other people completed this guide.
Sebastian
33,352 Reputation
72 Guides authored
German Translators Member of German Translators
Community
51 Members
1,731 Guides authored
13 Guide Comments
gut erklärt.Aber eine frage habe ich bringt so ein update was ?????
Alex Kahle - Reply Share
Ja, auf der Wiki Seite steht sogar welche Bugs gefixt wurden.
Sebastian - Reply Share
Danke für deine Antwort
Frage habe die Versionsnummer 50.00.000 ist die alt ?
und bleibt mein DAB+ radio und meine lenkrad steuerung nach den update.
Version 50 ist die neuste und letzte, du musst also kein Update machen.
I had tried update firmware in my outlander 2016. Now my car doesn't even detect hands free module at all. I had removed battery power supply and tried again but hands free module doesn't show in service mode. Please support.. How can i make it work? It seems there ia firmware mismatch. How can i repair it? Is there software available to connect with this HFM? Please help.
ABD - Reply Share
Past 24 Hours: 9
Past 7 Days: 58
Past 30 Days: 256
All Time: 10,669
