Up to 20% off select tools
Mitsubishi Diamondpoint NXM76LCD Display Replacement
View statistics:
Past 24 Hours:
Past 7 Days:
20
Past 30 Days:
97
All Time:
948
Comments: 0
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 15 - 45 minutes
Difficulty: Moderate
Community-Contributed Guide
Tools
    1. Mitsubishi Diamondpoint NXM76LCD  Display  Replacement, Removing the stand.: step 1, image 1 of 3 Mitsubishi Diamondpoint NXM76LCD  Display  Replacement, Removing the stand.: step 1, image 2 of 3 Mitsubishi Diamondpoint NXM76LCD  Display  Replacement, Removing the stand.: step 1, image 3 of 3
      • Lift the black cover off.
      • Remove all 4 Phillips #2 screws.
      Ask FixBot
    1. Mitsubishi Diamondpoint NXM76LCD  Display  Replacement, Remove the 5 screws: step 2, image 1 of 1
      • Remove the two 24mm Phillips #2 screws.
      • Remove the three 8mm Phillips #2 screws.
      Ask FixBot
    2. Mitsubishi Diamondpoint NXM76LCD  Display  Replacement, Remove the back panel: step 3, image 1 of 3 Mitsubishi Diamondpoint NXM76LCD  Display  Replacement, Remove the back panel: step 3, image 2 of 3 Mitsubishi Diamondpoint NXM76LCD  Display  Replacement, Remove the back panel: step 3, image 3 of 3
      • Lift the back and pry the back off.
      • The panel is held in with clips on the side. It needs a lot of force the take it off.
      Ask FixBot
    3. Mitsubishi Diamondpoint NXM76LCD  Display  Replacement, Remove the four screws: step 4, image 1 of 2 Mitsubishi Diamondpoint NXM76LCD  Display  Replacement, Remove the four screws: step 4, image 2 of 2
      • Remove the four 5mm nut screws.
      Ask FixBot
    4. Mitsubishi Diamondpoint NXM76LCD  Display  Replacement, Remove the 5 screws: step 5, image 1 of 2 Mitsubishi Diamondpoint NXM76LCD  Display  Replacement, Remove the 5 screws: step 5, image 2 of 2
      • Remove the seven Phillips #1 screws.
      Ask FixBot
    5. Mitsubishi Diamondpoint NXM76LCD  Display  Replacement, Remove the front panel: step 6, image 1 of 2 Mitsubishi Diamondpoint NXM76LCD  Display  Replacement, Remove the front panel: step 6, image 2 of 2
      • Remove the three Phillips #2 screws.
      • Remove the two data/power cables.
      • Remove the two speaker cables.
      Ask FixBot
    6. Mitsubishi Diamondpoint NXM76LCD  Display  Replacement, Remove the display cable: step 7, image 1 of 3 Mitsubishi Diamondpoint NXM76LCD  Display  Replacement, Remove the display cable: step 7, image 2 of 3 Mitsubishi Diamondpoint NXM76LCD  Display  Replacement, Remove the display cable: step 7, image 3 of 3
      • Pull the two tabs.
      • Pull the connector off.
      Ask FixBot
    7. Mitsubishi Diamondpoint NXM76LCD  Display  Replacement, Remove the power switch: step 8, image 1 of 2 Mitsubishi Diamondpoint NXM76LCD  Display  Replacement, Remove the power switch: step 8, image 2 of 2
      • Remove the switch cable off.
      • Remove the two Phillips #2 screws.
      Ask FixBot
    8. Mitsubishi Diamondpoint NXM76LCD  Display  Replacement, Remove the display power: step 9, image 1 of 2 Mitsubishi Diamondpoint NXM76LCD  Display  Replacement, Remove the display power: step 9, image 2 of 2
      • Remove the four display power cables.
      • These cables are interchangeable.
      Ask FixBot
    9. Mitsubishi Diamondpoint NXM76LCD  Display  Replacement, Lift the display out: step 10, image 1 of 3 Mitsubishi Diamondpoint NXM76LCD  Display  Replacement, Lift the display out: step 10, image 2 of 3 Mitsubishi Diamondpoint NXM76LCD  Display  Replacement, Lift the display out: step 10, image 3 of 3
      • Lift the display out.
      Ask FixBot
    10. Mitsubishi Diamondpoint NXM76LCD  Display  Replacement, Remove the four screws: step 11, image 1 of 2 Mitsubishi Diamondpoint NXM76LCD  Display  Replacement, Remove the four screws: step 11, image 2 of 2
      • Remove the four Phillips #2 screws.
      • These screws release the display from its enclosure. Hold the screen when removing these screws.
      Ask FixBot
    11. Mitsubishi Diamondpoint NXM76LCD  Display  Replacement: step 12, image 1 of 2 Mitsubishi Diamondpoint NXM76LCD  Display  Replacement: step 12, image 2 of 2
      • Remember to plug in all the cables on the display.
      Ask FixBot
2 other people completed this guide.
Author
with
Padraic Hoselton
4,452 Reputation
12 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 20
Past 30 Days: 97
All Time: 948
