Mitchell Epic Series E150 Disassembly
    1. Mitchell Epic Series E150 Disassembly, Removing the Spool Cover: step 1, image 1 of 1
      • Start by removing screws 1,2, and 3 with a small phillips screwdriver.
      Ask FixBot
    2. Mitchell Epic Series E150 Disassembly, Removing the Spool: step 2, image 1 of 1
      • Remove the spool from the reel, making sure that the small rubber centrifugal brakes don’t fall off.
      Ask FixBot
    3. Mitchell Epic Series E150 Disassembly, Removing the Center Body from the Handle Plate: step 3, image 1 of 1
      • Loosen fasteners 4, 5, and 6 with a flat blade screwdriver.
      • Separate the center body of the reel from the handle plate.
      • Remove screw 9 holding in the retaining cap.
      Ask FixBot
    4. Mitchell Epic Series E150 Disassembly, Removing the Handle: step 4, image 1 of 1
      • Remove retaining clip r1 with a flat blade screwdriver
      • Note: It is very easy to accidentally lose this retaining clip, be sure to hold the clip while prying with your flat blade screwdriver
      Ask FixBot
    5. Mitchell Epic Series E150 Disassembly, Removing the Handle: step 5, image 1 of 1
      • Remove washer ,w1, under retaining clip r1.
      • Remove handle retaining nut, n1, using a small adjustable wrench.
      • Remove handle.
      Ask FixBot
    6. Mitchell Epic Series E150 Disassembly, Removing Star Drag Assembly: step 6, image 1 of 1
      • Remove handle spring washer, w2.
      • Remove star drag assembly, STA, by turning it counter clockwise while holding. the shaft it’s sitting on.(You can use the adjustable wrench to hold the square. part. of the shaft.)
      Ask FixBot
    7. Mitchell Epic Series E150 Disassembly, Removing Cast Controls: step 7, image 1 of 2 Mitchell Epic Series E150 Disassembly, Removing Cast Controls: step 7, image 2 of 2
      • Remove cast control knob, CCK.
      • Remove cast control spring, CCS.
      Ask FixBot
    8. Mitchell Epic Series E150 Disassembly, Removing Drag Assembly: step 8, image 1 of 3 Mitchell Epic Series E150 Disassembly, Removing Drag Assembly: step 8, image 2 of 3 Mitchell Epic Series E150 Disassembly, Removing Drag Assembly: step 8, image 3 of 3
      • Remove main shaft bearing, MSB, drag pressure insert, DPI, drag washers, dw1, dw2, and drag spring washer, dsw.
      Ask FixBot
    9. Mitchell Epic Series E150 Disassembly, Removing Set Plate: step 9, image 1 of 2 Mitchell Epic Series E150 Disassembly, Removing Set Plate: step 9, image 2 of 2
      • Remove screw 7, and 8 with a phillips screwdriver.
      • Remove set plate assembly, SPA.
      Ask FixBot
    10. Mitchell Epic Series E150 Disassembly, Removing Rotating Assembly: step 10, image 1 of 2 Mitchell Epic Series E150 Disassembly, Removing Rotating Assembly: step 10, image 2 of 2
      • Remove crankshaft assembly, CSA, and reverse lockout claw, RLC.
      • Slowly remove thumb latch, TL, to avoid losing the return spring.
      • Remove washers, w3,w4.
      • Remove screw, 10, holding down latch keeper.
      Ask FixBot
    11. Mitchell Epic Series E150 Disassembly, Disassembling Drag Gears: step 11, image 1 of 1
      • Remove drag pressure plate, DPP, from crankshaft assembly.
      • Remove main gear, MG from crankshaft assembly.
      Ask FixBot
    12. Mitchell Epic Series E150 Disassembly, Disassembling Center Body: step 12, image 1 of 2 Mitchell Epic Series E150 Disassembly, Disassembling Center Body: step 12, image 2 of 2
      • Remove line guide cap, LGC, with a flat blade screwdriver.
      • Remove line guide retainer, LGR.
      • Remove line guide gear retainer, LGGR, by pushing it off with a flat blade screwdriver.
      Ask FixBot
    13. Mitchell Epic Series E150 Disassembly, Disassembling Line Guide: step 13, image 1 of 1
      • Remove line guide bushing, LGB.
      • Remove line guide shaft, LGS, by pushing on the side that the line guide bushing was removed from.
      Ask FixBot
To reassemble your fishing reel, follow these instructions in reverse order.
Kaden Morgan
218 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 13
Past 30 Days: 33
All Time: 302
