Up to 20% off select tools
Mirror Box Removal
Views: 1.1K
View statistics:
Past 24 Hours:
5
Past 7 Days:
25
Past 30 Days:
120
All Time:
1,074
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 2 hours
Difficulty: Very difficult
Community-Contributed Guide
Mirror Box Removal
Tools
    1. Mirror Box Removal, Remove film door: step 1, image 1 of 1
      • Push down the latch to release the film door.
      Ask FixBot
    2. Mirror Box Removal, Remove top cover screws: step 2, image 1 of 3 Mirror Box Removal, Remove top cover screws: step 2, image 2 of 3 Mirror Box Removal, Remove top cover screws: step 2, image 3 of 3
      • Remove two 7.5 mm #00 screws.
      • Remove one 9.0 mm #00 screw.
      • Remove one 13.5 mm #00 screw from inside the battery compartment.
      Ask FixBot
    3. Mirror Box Removal, Remove top cover screws: step 3, image 1 of 3 Mirror Box Removal, Remove top cover screws: step 3, image 2 of 3 Mirror Box Removal, Remove top cover screws: step 3, image 3 of 3
      • Push the button to pop up the flash.
      • Remove one 3.5 mm #00 screw.
      • Remove one 5.5 mm #00 screw.
      Ask FixBot
    4. Mirror Box Removal, Lift top cover: step 4, image 1 of 1
      • Carefully lift the top cover away from the body to access wired connections.
      • The top cover is still connected in several locations.
      Ask FixBot
    5. Mirror Box Removal, Access flash connections: step 5, image 1 of 2 Mirror Box Removal, Access flash connections: step 5, image 2 of 2
      • Peel back the corner of the rubber grip.
      • Remove the small plastic cover.
      • Be careful not to short the wires before the flash capacitors have been properly discharged.
      Ask FixBot
    6. Mirror Box Removal, Discharge flash capacitors: step 6, image 1 of 1
      • Use a 1kΩ-10kΩ high power resistor to discharge the capacitor. Place the resistor between the blue wire, exposed in the previous step, and ground.
      • The flash capacitors store energy at a very high voltage. Failing to discharge the capacitors properly could result in personal injury and/or damage to the camera.
      Ask FixBot
    7. Mirror Box Removal, Disconnect right flex cable: step 7, image 1 of 1
      • Carefully lift the sides of the white latch.
      • Hold the flex PCB on the camera body in place as you lift to prevent damaging the flex.
      Ask FixBot
    8. Mirror Box Removal, Disconnect left flex cable: step 8, image 1 of 1
      • Desolder the red wire.
      Ask FixBot
    9. Mirror Box Removal, Desolder flash connections: step 9, image 1 of 2 Mirror Box Removal, Desolder flash connections: step 9, image 2 of 2
      • Desolder blue, black, brown and green wires.
      • Remove the loose shim washer if present.
      Ask FixBot
    10. Mirror Box Removal, Desolder the flash flex cable: step 10, image 1 of 2 Mirror Box Removal, Desolder the flash flex cable: step 10, image 2 of 2
      • Remove the piece of cellophane tape covering the flex connections.
      • Desolder flex connetions.
      Ask FixBot
    1. Mirror Box Removal, Remove bottom cover: step 11, image 1 of 3 Mirror Box Removal, Remove bottom cover: step 11, image 2 of 3 Mirror Box Removal, Remove bottom cover: step 11, image 3 of 3
      • Use isopropyl alcohol to soften the adhesive under the country plate and remove.
      • Remove one 5mm #00 screw.
      • Remove one 7.5mm #00 screw.
      • Remove two 4.5mm #00 screws.
      • Remove one 5.5mm #00 screw.
      • Remove the plastic frame around the accessory grip contacts.
      • Reassembly Note: The camera can be checked for functionality at this point. Install the rear door, insert a fresh pair of batteries and try to fire the shutter.
      Ask FixBot
    2. Mirror Box Removal, Remove front left cover: step 12, image 1 of 1
      • Remove one 4.0 mm #00 screw.
      • Remove left cover.
      Ask FixBot
    3. Mirror Box Removal, Remove front cover: step 13, image 1 of 1
      • Remove front cover.
      Ask FixBot
    4. Mirror Box Removal, Unscrew front right cover: step 14, image 1 of 3 Mirror Box Removal, Unscrew front right cover: step 14, image 2 of 3 Mirror Box Removal, Unscrew front right cover: step 14, image 3 of 3
      • Remove one 6.0 mm #00 screw.
      • Remove two 3.5 mm #00 screws.
      • Remove one 5.0 mm #00 screw.
      • Remove the strap lug.
      Ask FixBot
    5. Mirror Box Removal, Remove the front right cover: step 15, image 1 of 1
      • Carefully pull the right panel away from the body. It is still attached.
      • Desolder the flex connections.
      Ask FixBot
    1. Mirror Box Removal, Remove bottom plate: step 16, image 1 of 3 Mirror Box Removal, Remove bottom plate: step 16, image 2 of 3 Mirror Box Removal, Remove bottom plate: step 16, image 3 of 3
      • Remove the protective mask around the accessory grip contacts.
      • Lift the flex contacts free of their retaining posts. Use isopropyl alcohol to soften any glue or tape that is present.
      • Remove four 4.0 mm #00 screws (standard metric threads).
      • Remove four 4.0 mm #00 screws (plastic threads).
      Ask FixBot
    2. Mirror Box Removal, Desolder speaker: step 17, image 1 of 1
      • Desolder the black and red wires for the speaker.
      Ask FixBot
    3. Mirror Box Removal, Desolder connections to bottom flex circuit: step 18, image 1 of 3 Mirror Box Removal, Desolder connections to bottom flex circuit: step 18, image 2 of 3 Mirror Box Removal, Desolder connections to bottom flex circuit: step 18, image 3 of 3
      • Desolder the white and pink wires.
      • Desolder the red, black and gray wires.
      • Desolder the red, black and orange wires.
      • Desolder the white and blue wires.
      • Carefully peal the tape away and detach the red, black, white and blue wires from the glue. Use isopropyl alcohol to soften the glue if necessary.
      • Desolder the flex connection.
      Ask FixBot
    4. Mirror Box Removal, Desolder connections to top flex circuit: step 19, image 1 of 3 Mirror Box Removal, Desolder connections to top flex circuit: step 19, image 2 of 3 Mirror Box Removal, Desolder connections to top flex circuit: step 19, image 3 of 3
      • Desolder red, black, gray and orange wires.
      • Desolder flex contacts.
      • Disconnect flex connector.
      • Desolder yellow and purple wires.
      Ask FixBot
    5. Mirror Box Removal, Desolder connections to top flex circuit: step 20, image 1 of 2 Mirror Box Removal, Desolder connections to top flex circuit: step 20, image 2 of 2
      • Desolder black wire.
      • Desolder battery contact tab.
      Ask FixBot
    6. Mirror Box Removal, Desolder flex connection above the lens mount: step 21, image 1 of 2 Mirror Box Removal, Desolder flex connection above the lens mount: step 21, image 2 of 2
      • Desolder flex connection and remove from retention posts. Use isopropyl alcohol to soften the glue if necessary.
      • Carefully peal the flex cable from the surface of the flash capacitor. Use isopropyl alcohol to soften the glue if necessary.
      Ask FixBot
    7. Mirror Box Removal, Remove eye piece assembly: step 22, image 1 of 2 Mirror Box Removal, Remove eye piece assembly: step 22, image 2 of 2
      • Remove two 5.0 mm #00 screws.
      • Remove the eye piece.
      • The outer cover of the eye piece is only attached with double sided tape and may come away on its own. Make sure the entire eye piece unit is removed before proceeding.
      Ask FixBot
    8. Mirror Box Removal, Remove lens release switch: step 23, image 1 of 2 Mirror Box Removal, Remove lens release switch: step 23, image 2 of 2
      • Remove one #00 screw.
      • Reassembly Note: Ensure that the lower contact catches on the plastic nub and that the contact is open when the lens release button is not pressed.
      Ask FixBot
    9. Mirror Box Removal, Flip the mirror up: step 24, image 1 of 2 Mirror Box Removal, Flip the mirror up: step 24, image 2 of 2
      • Rotate the black gear downward until the mirror flips up into the taking position. It may take several turns.
      • Some failures will result in the mirror appearing to be in the upper position but the internal mechanism is still "down". The mechanism needs to be moved to release the mirror box.
      Ask FixBot
    10. Mirror Box Removal, Detach flex circuit: step 25, image 1 of 2 Mirror Box Removal, Detach flex circuit: step 25, image 2 of 2
      • Remove one 4.0 mm screw.
      • Gently lift the flex circuit away from the housing.
      Ask FixBot
    11. Mirror Box Removal, Unscrew the mirror box: step 26, image 1 of 2 Mirror Box Removal, Unscrew the mirror box: step 26, image 2 of 2
      • Remove two 6.5 mm #0 screws.
      • Remove one 8.0 mm #0 screw.
      • Remove one 4.5 mm #00 screw.
      • Remove two 2.5 mm #00 screws.
      • There may be a shim washer here. Remove if loose.
      • Remove one 4.0 mm #00 shoulder screw.
      Ask FixBot
    12. Mirror Box Removal, Remove the mirror box: step 27, image 1 of 2 Mirror Box Removal, Remove the mirror box: step 27, image 2 of 2
      • Push the mirror box up to free it from the bottom plate.
      • Lift the left side of the mirror box and rotate it up and out of the camera body.
      • Be gentle. Keep an eye out for any snagged flex cables or wires. The right side of the mirror box is still connected to the camera body and it cannot be completely removed.
      • Check for shim washers at the mount locations. Note location and remove if loose.
      Ask FixBot
Author
with
Sam Gustafson
14,888 Reputation
78 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 25
Past 30 Days: 120
All Time: 1,074
