Up to 20% off select tools
Miroir M631 LED Mini Projector Disassembly
Views: 3.1K
View statistics:
Past 24 Hours:
4
Past 7 Days:
21
Past 30 Days:
111
All Time:
3,146
Comments: 10
8 comments on steps, 2 guide comments.
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 1 hour
Difficulty: Moderate
Community-Contributed Guide
Tools
    1. Miroir M631 LED Mini Projector Disassembly, Front and rear bezel removal: step 1, image 1 of 2 Miroir M631 LED Mini Projector Disassembly, Front and rear bezel removal: step 1, image 2 of 2
      • Ensure that the lens cover is fully closed.
      • Using the iFixit Jimmy (or similar tool), pry off the front bezel, starting at the opposite end to the lens.
      • Turn the projector over and remove the rear bezel in thesame way. (You can start at either end.)
      Ask FixBot
    2. Miroir M631 LED Mini Projector Disassembly, Case retaining screws: step 2, image 1 of 2 Miroir M631 LED Mini Projector Disassembly, Case retaining screws: step 2, image 2 of 2
      • Remove 7 screws from the front.
      • Remove 5 screws from the back.
      Ask FixBot
    3. Miroir M631 LED Mini Projector Disassembly, Opening the case: step 3, image 1 of 2 Miroir M631 LED Mini Projector Disassembly, Opening the case: step 3, image 2 of 2
      • Using the jimmy (or similar) release the clips retaining the top cover, starting at the front on the lens side (as shown).
      • Repeat on the other side, starting at the front or the back, whichever accepts the jimmy most easily.
      • Lift off the cover, gently releasing a remaining clip behind the buttons, if it's still engaged.
      Ask FixBot
    4. Miroir M631 LED Mini Projector Disassembly, Disconnecting connectors - 1: step 4, image 1 of 3 Miroir M631 LED Mini Projector Disassembly, Disconnecting connectors - 1: step 4, image 2 of 3 Miroir M631 LED Mini Projector Disassembly, Disconnecting connectors - 1: step 4, image 3 of 3
      Tool used on this step:
      Buy
      • Before doing anything else, release the battery connector, easing it with a pair of tweezers so as not to strain the wires.
      • In the same way, release four connectors with red, green, blue and black wires
      • Similarly, release the fan connector, two connectors to the focus motor and an adjacent sensor board, and the two speaker connectors.
      Ask FixBot
    5. Miroir M631 LED Mini Projector Disassembly, Disconnecting connectors - 2: step 5, image 1 of 2 Miroir M631 LED Mini Projector Disassembly, Disconnecting connectors - 2: step 5, image 2 of 2
      • Very gently lift the locking tabs on three ribbon connectors. A plastic prying tool is good for this. Withdraw the ribbons.
      • On reconnecting the ribbons, make sure they are fully inserted into their connectors before gently pushing down the locking tabs. This can be a little fiddly.
      Ask FixBot
    6. Miroir M631 LED Mini Projector Disassembly, Disconnecting the video ribbon: step 6, image 1 of 2 Miroir M631 LED Mini Projector Disassembly, Disconnecting the video ribbon: step 6, image 2 of 2
      • Carefully peel back the copper foil covering the video connector until you can unmate it. Try not to tear the foil.
      • On reassembly, make sure the video connector is properly mated before pressing down the copper foil. You should feel a definite click as it mates. Ensure that both ends are mated.
      Ask FixBot
    7. Miroir M631 LED Mini Projector Disassembly, Motherboard removal: step 7, image 1 of 2 Miroir M631 LED Mini Projector Disassembly, Motherboard removal: step 7, image 2 of 2
      • Remove 4 screws securing the motherboard.
      • You should now be able to lift the motherboard clear, moving disconnected cables out of the way as you do so.
      • On reassembly, ensure that no cables or ribbons are trapped under the motherboard before replacing the 4 screws.
      Ask FixBot
    8. Miroir M631 LED Mini Projector Disassembly, Ancilliary components: step 8, image 1 of 1
      • If required, you can now easily remove:
      • the buttons board
      • the speakers
      • or the lens cover sensor.
      Ask FixBot
    9. Miroir M631 LED Mini Projector Disassembly, Removing the optical assembly - 1: step 9, image 1 of 2 Miroir M631 LED Mini Projector Disassembly, Removing the optical assembly - 1: step 9, image 2 of 2
      • Remove a screw at the right hand end of the cover between the fan and the grill. (The screw at the other end was removed in removing the motherboard.)
      • Lift off this cover. Note that it's a snug fit. On refitting, ensure that the screw holes are correctly aligned with the pillars the screws scew into.
      • On reassembly, if you have removed the optical assembly and/or the fan, don't finally tighten the screws on these until you've refitted the fan/grill cover.
      Ask FixBot
    10. Miroir M631 LED Mini Projector Disassembly, Removing the optical assembly - 2: step 10, image 1 of 3 Miroir M631 LED Mini Projector Disassembly, Removing the optical assembly - 2: step 10, image 2 of 3 Miroir M631 LED Mini Projector Disassembly, Removing the optical assembly - 2: step 10, image 3 of 3
      • Lift the tape securing the red, green, blue and black wires to the battery so as to free those wires.
      • Remove 3 screws retaining the optical assembly. The entire assembly can now be lifted out.
      Ask FixBot
    11. Miroir M631 LED Mini Projector Disassembly, Removing the fan: step 11, image 1 of 1
      • Remove 2 screws securing the fan. This can now be lifted out allowing any dust build-up on th grill to be cleaned out.
      Ask FixBot
    12. Miroir M631 LED Mini Projector Disassembly, Battery removal: step 12, image 1 of 1
      • The battery is securely glued to the base of the projector. If you need to remove it, take great care not to damage it as you do so.
      • As you apply a continual upwards force the adhesice should very slowly give. Gentle warmth should aid the process but on no account rush it. Insert packing underneed as it lifts to prevent the adhesive taking hold again.
      Ask FixBot
Author
with
Philip Le Riche
32,799 Reputation
48 Guides authored
Restart Project Member of Restart Project
Local Repair Groups
35 Members
2,412 Guides authored
2 Guide Comments
Bonjour pour les fils noir bleu orange jaune et rouge du moteur de la lentille, quel est le sens couleur. ?
Julien LHERBÉ - Reply Share
Hi, can you do disassembly for wemax go 300?, is it the same like this one?
Asr - Reply Share
Past 24 Hours: 4
Past 7 Days: 21
Past 30 Days: 111
All Time: 3,146
