Mio Alpha 2 Charging Pins Replacement
Views: 1.4K
View statistics:
Past 24 Hours:
2
Past 7 Days:
14
Past 30 Days:
44
All Time:
1,357
Comments: 3
1 comment on steps, 2 guide comments.
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 9 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
If your Mio ALPHA 2 heat rate monitor watch is not charging properly, it is possible that the charging pins need to be replaced. This guide will teach you how to remove the charging pins. You will need small tools to remove the cover on the back of the device. These tools will also need to be used to remove the charging pins. There are many small parts, so it is important to be in an environment where they will not be lost.
Tools
    1. Mio Alpha 2 Charging Pins Replacement, Charging Pins: step 1, image 1 of 1
      • Remove the four 6.7mm JIS #00 screws from the back cover.
      Ask FixBot
    2. Mio Alpha 2 Charging Pins Replacement: step 2, image 1 of 2 Mio Alpha 2 Charging Pins Replacement: step 2, image 2 of 2
      • Remove the gold coils from the bottom of the pin. Remove the washer from the pin with the spudger.
      Ask FixBot
    3. Mio Alpha 2 Charging Pins Replacement: step 3, image 1 of 2 Mio Alpha 2 Charging Pins Replacement: step 3, image 2 of 2
      • Pop the pins out one at a time using the spudger.
      Ask FixBot
Finish Line
Stefan Tracogna
1 Reputation
1 Guide authored
IUPUI, Team S22-G3, Bayer Fall 2017 Member of IUPUI, Team S22-G3, Bayer Fall 2017
IUPUI-BAYER-F17S22G3
4 Members
24 Guides authored
2 Guide Comments
How are you "replacing" a part with no parts required.... would be super cool to have the part number or any information on those pins.
mattgrimshaw91 - Reply Share
How do I charge it without a charger? I just got this watch uncharged and it didn't come with a charger.
Leslye - Reply Share
Past 24 Hours: 2
Past 7 Days: 14
Past 30 Days: 44
All Time: 1,357
