Up to 20% off select tools
Mio ALPHA 2 Screen Replacement
View statistics:
Past 24 Hours:
3
Past 7 Days:
14
Past 30 Days:
62
All Time:
855
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 5 minutes
Difficulty: Moderate
Parts
Tools
Introduction
Go to step 1 ↓
To replace the screen of the Mio ALPHA 2, firstly you would need a proper repair toolkit. This is a relatively easy replacement as you would only need a Philip screwdriver with a PH0 head and tweezers. Be careful not to apply too much force or tug the cords inside.
This guide would be helpful if you're trying to replace the screen of your Mio ALPHA 2.
    1. Mio ALPHA 2 Screen Replacement, Motherboard: step 1, image 1 of 2 Mio ALPHA 2 Screen Replacement, Motherboard: step 1, image 2 of 2
      • Remove the four 6.7mm JIS #00 screws from the back cover.
      Ask FixBot
    2. Mio ALPHA 2 Screen Replacement: step 2, image 1 of 3 Mio ALPHA 2 Screen Replacement: step 2, image 2 of 3 Mio ALPHA 2 Screen Replacement: step 2, image 3 of 3
      Tool used on this step:
      Buy
      • Pull off the back cover of the watch
      • Use a pair of tweezers to flip up the retaining flap on the ribbon cable ZIF socket.
      • Remove the ribbon cable from its socket.
      Ask FixBot
    3. Mio ALPHA 2 Screen Replacement: step 3, image 1 of 3 Mio ALPHA 2 Screen Replacement: step 3, image 2 of 3 Mio ALPHA 2 Screen Replacement: step 3, image 3 of 3
      • Remove the four 3.8mm JIS #00 screws from the motherboard.
      • Remove the motherboard with tweezers
      Ask FixBot
    1. Mio ALPHA 2 Screen Replacement, Screen: step 4, image 1 of 1
      Buy
      Ask FixBot
Author
with
Wong Jun Hua
169 Reputation
2 Guides authored
IUPUI, Team S1-G3, Harley Spring 2018 Member of IUPUI, Team S1-G3, Harley Spring 2018
IUPUI-HARLEY-S18S1G3
6 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 14
Past 30 Days: 62
All Time: 855
