Inconsistent Images
Updating the images on this guide to be more consistent with the prerequisites would increase its awesomeness.
Tools
Introduction
Go to step 1 ↓The outer casing of the camera is the first step to fixing any internal hardware. It is essential that the outer casing is in proper condition and not damaged to ensure the integrity of the internal components.
To reassemble your device, follow these instructions in reverse order. The outer casing must be properly in place and screws tight to protect the internal hardware.
2 Guide Comments
I was having an issue attaching the ribbon cable from the half of the shell with the buttons. It is pretty tight and hard to handle, but is do able without tools. Try holding it with a finger thought the screen hole.
However, just because the ribbon "latches" does not mean it is seated right. A lose connection seems to stop SOME of the buttons from working, which had me thinking I broke it. The ribbon needed to be pushed in rather "hard" and latched straight in the housing. Took me a few tries.
