Up to 20% off select tools
Mini Fridge Hinges Replacement
Views: 7.1K
View statistics:
Past 24 Hours:
10
Past 7 Days:
60
Past 30 Days:
264
All Time:
7,103
Comments: 2
1 comment on steps, 1 guide comment.
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 15 minutes
Difficulty: Easy
Tools
Introduction
Go to step 1 ↓
Is your mini fridge door not working properly? Are you having trouble keeping the door closed and the contents cold? You may want to inspect the quality of the hinges connecting your door to the fridge.
This guide is designed to assist you in replacing your mini fridge hinges. Before replacing your hinges verify that there are not any underlying problems with your door seal and mechanical components. Should these remain functional but the hinges are not you can proceed to follow this guide.
These hinges can become damaged, rusted, or worn over time resulting in poor functionality of the fridge door. This repair can be completed by one person but an assistant is helpful.
    1. Mini Fridge Hinges Replacement, Hinges: step 1, image 1 of 1
      • Remove the plug from the outlet. Be sure to grab from the head of the cord.
      Ask FixBot
    2. Mini Fridge Hinges Replacement: step 2, image 1 of 1
      • Remove all food items and shelves from the fridge.
      • Place removed contents to the side and if needed place food items in another fridge temporarily.
      Ask FixBot
    3. Mini Fridge Hinges Replacement: step 3, image 1 of 2 Mini Fridge Hinges Replacement: step 3, image 2 of 2
      • Remove the cover to the top hinge to access the hinge and screws. If you are unable to remove the cover with your hands, use a flathead screwdriver to pry it off.
      • Remove the three 20 mm Phillips #1 screws from beneath the cover.
      Ask FixBot
    4. Mini Fridge Hinges Replacement: step 4, image 1 of 3 Mini Fridge Hinges Replacement: step 4, image 2 of 3 Mini Fridge Hinges Replacement: step 4, image 3 of 3
      • After removing the top hinge, lift the door off of the bottom hinge.
      • Place the door and removed top hinge securely to the side.
      Ask FixBot
    5. Mini Fridge Hinges Replacement: step 5, image 1 of 2 Mini Fridge Hinges Replacement: step 5, image 2 of 2
      • Rotate the fridge onto its side.
      • Do not turn the fridge upside down to protect the internal components of the fridge.
      • Remove the two 19 mm Phillips #1 screws and the bottom hinge.
      Ask FixBot
    6. Mini Fridge Hinges Replacement: step 6, image 1 of 1
      • Install the bottom replacement hinge and the two 19 mm Phillips #1 screws.
      • Turn the fridge right side up after the bottom hinge is replaced.
      Ask FixBot
    7. Mini Fridge Hinges Replacement: step 7, image 1 of 1
      • Place the door on the bottom hinge, aligning the hole with the hinge.
      • Install the new top hinge and the three 20 mm Philips #1 screws. Ensure the orientation of the hinge lines up with the door.
      • Tighten as needed until the fridge door opens and closes normally and is not uneven.
      • Replace the top cover and the shelving inside the fridge.
      Ask FixBot
This is a relatively easy fix and is easily repeatable. The replacement parts are inexpensive. We hope this guide extends the life of a mini fridge and expands your understanding of the topic.
Author
with
Adam Millen
169 Reputation
1 Guide authored
1 Guide Comment
My fridge is not working Death ho gaya h bikul kuch bbi n chal rha h
Prince Singh - Reply Share
Past 24 Hours: 10
Past 7 Days: 60
Past 30 Days: 264
All Time: 7,103
