Milwaukee M18 2891-20 Main Drivers Replacement
    1. Milwaukee M18 2891-20 Main Drivers Replacement, Driver Assembly: step 1, image 1 of 3 Milwaukee M18 2891-20 Main Drivers Replacement, Driver Assembly: step 1, image 2 of 3 Milwaukee M18 2891-20 Main Drivers Replacement, Driver Assembly: step 1, image 3 of 3
      • Remove the battery before beginning disassembly.
      • Use a 2.5 hex bit head screwdriver to remove the six 14 mm outermost screws located on each end of the speaker.
      • Insert an pry tool underneath the red decal located on the side of the speaker.
      • Pry up slowly to unclip the two clips, one under each end of the decal, that are holding it to the speaker and remove the decal.
      Ask FixBot
    2. Milwaukee M18 2891-20 Main Drivers Replacement: step 2, image 1 of 2 Milwaukee M18 2891-20 Main Drivers Replacement: step 2, image 2 of 2
      • Use a Phillips #2 screwdriver to remove the three 14 mm screws that were underneath the red decal, and the two screws above the battery port.
      • Remove the four 14 mm Phillips #2 screws that are in the corners holding the front speaker cover.
      Ask FixBot
    3. Milwaukee M18 2891-20 Main Drivers Replacement: step 3, image 1 of 2 Milwaukee M18 2891-20 Main Drivers Replacement: step 3, image 2 of 2
      • Insert a pry tool in between the speaker cover and the speaker and gently pry the front speaker cover off of the speaker.
      • Remove the speaker cover.
      Ask FixBot
    4. Milwaukee M18 2891-20 Main Drivers Replacement: step 4, image 1 of 2 Milwaukee M18 2891-20 Main Drivers Replacement: step 4, image 2 of 2
      • Use a Phillips #2 screwdriver to remove the five 14 mm screws on the ends of the speaker box.
      Ask FixBot
    5. Milwaukee M18 2891-20 Main Drivers Replacement: step 5, image 1 of 2 Milwaukee M18 2891-20 Main Drivers Replacement: step 5, image 2 of 2
      • Use a Phillips #2 screwdriver to remove the eleven 14 mm screws securing the driver assembly.
      • Use a pry tool and gently pry the driver housing up.
      • Lift the driver housing with care not to strain or damage the connected cables.
      Ask FixBot
    6. Milwaukee M18 2891-20 Main Drivers Replacement: step 6, image 1 of 2 Milwaukee M18 2891-20 Main Drivers Replacement: step 6, image 2 of 2
      • Disconnect the two driver JST connectors.
      • Disconnect the driver assembly ribbon cable.
      • Fully remove the driver assembly.
      Ask FixBot
    1. Milwaukee M18 2891-20 Main Drivers Replacement, Main Drivers: step 7, image 1 of 2 Milwaukee M18 2891-20 Main Drivers Replacement, Main Drivers: step 7, image 2 of 2
      • Use a Phillips #2 screwdriver to remove the eight 14 mm screws securing the two main drivers.
      Ask FixBot
    2. Milwaukee M18 2891-20 Main Drivers Replacement: step 8, image 1 of 2 Milwaukee M18 2891-20 Main Drivers Replacement: step 8, image 2 of 2
      • Desolder the wires that are connected to the main speakers as shown.
      • Use caution while using the soldering iron.
      • If you're unfamiliar with soldering, please review the How to Solder and Desolder Connections guide.
      • Gently remove the drivers.
      Ask FixBot
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
0 Guide Comments
Past 24 Hours: 6
Past 7 Days: 18
Past 30 Days: 67
All Time: 254
