Milwaukee M18 2606-20 Trigger Replacement
  1. Milwaukee M18 2606-20 Trigger Replacement, Trigger: step 1, image 1 of 2 Milwaukee M18 2606-20 Trigger Replacement, Trigger: step 1, image 2 of 2
    • Remove the seven 18 mm screws, using the T3 Torx Screwdriver, from the handle area of the case.
    • Remove the two 21 mm screws, using the T3 Torx Screwdriver, from the top of the case.
    Ask FixBot
  2. Milwaukee M18 2606-20 Trigger Replacement: step 2, image 1 of 3 Milwaukee M18 2606-20 Trigger Replacement: step 2, image 2 of 3 Milwaukee M18 2606-20 Trigger Replacement: step 2, image 3 of 3
    • Remove the four 20 mm screws, using the T3 Torx Screwdriver, from the front of the case.
    Ask FixBot
  3. Milwaukee M18 2606-20 Trigger Replacement: step 3, image 1 of 2 Milwaukee M18 2606-20 Trigger Replacement: step 3, image 2 of 2
    • Peel back the sticker at the bottom of the drill handle.
    Ask FixBot
  4. Milwaukee M18 2606-20 Trigger Replacement: step 4, image 1 of 2 Milwaukee M18 2606-20 Trigger Replacement: step 4, image 2 of 2
    • Open the case by sliding the opening tool all the way around the case to pry it apart.
    Ask FixBot
  5. Milwaukee M18 2606-20 Trigger Replacement: step 5, image 1 of 2 Milwaukee M18 2606-20 Trigger Replacement: step 5, image 2 of 2
    Tool used on this step:
    Buy
    • Unplug the 4-pin connector, using the tweezers, from the circuit board.
    Ask FixBot
  6. Milwaukee M18 2606-20 Trigger Replacement: step 6, image 1 of 3 Milwaukee M18 2606-20 Trigger Replacement: step 6, image 2 of 3 Milwaukee M18 2606-20 Trigger Replacement: step 6, image 3 of 3
    • Desolder the wires soldered to the trigger.
    Ask FixBot
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 24
Past 30 Days: 134
All Time: 6,895
