Milwaukee M18 2606-20 Chuck Replacement
    1. Milwaukee M18 2606-20 Chuck Replacement, Chuck: step 1, image 1 of 3 Milwaukee M18 2606-20 Chuck Replacement, Chuck: step 1, image 2 of 3 Milwaukee M18 2606-20 Chuck Replacement, Chuck: step 1, image 3 of 3
      • Rotate the chuck counterclockwise to open the chuck jaws as far as possible.
      Ask FixBot
    2. Milwaukee M18 2606-20 Chuck Replacement: step 2, image 1 of 2 Milwaukee M18 2606-20 Chuck Replacement: step 2, image 2 of 2
      • Remove the 28 mm inner screw holding the chuck onto the drill using a Phillips #3 screwdriver.
      • Rotate the screw clockwise to loosen it.
      • The inner chuck screw is reverse threaded which is why it needs to be rotated clockwise.
      Ask FixBot
    3. Milwaukee M18 2606-20 Chuck Replacement: step 3, image 1 of 2 Milwaukee M18 2606-20 Chuck Replacement: step 3, image 2 of 2
      • Insert an Allen wrench into the chuck and tighten the chuck onto the wrench.
      • The Allen wrench will be used for leverage when removing the chuck.
      • When the chuck is tightened it could make a clicking sound. This is fine and is not causing any harm to the drill.
      Ask FixBot
    4. Milwaukee M18 2606-20 Chuck Replacement: step 4, image 1 of 3 Milwaukee M18 2606-20 Chuck Replacement: step 4, image 2 of 3 Milwaukee M18 2606-20 Chuck Replacement: step 4, image 3 of 3
      • Rotate the Allen wrench counterclockwise to remove the chuck.
      Ask FixBot
3 other people completed this guide.
4 Guide Comments
Milwaukee say to heat the tort screw up to loosen the locktite. Did this to the second chuck I replaced came off much easier. Getting the chuck off was a different story, tried hitting a 10mm allan key in the chuck didn’t work. Ended up getting a 10mm 1/2’ allan head socket on a breaker bar. Put the drill on the ground stood on it and with the other leg kicked the breaker bar. Came straight off.
tim.karen.collins - Reply Share
My chuck was stuck and working rough, needed to get it off the drill motor. Worked on a Harbor Freight Hercules 1/2” hammer/drill just fine. Neat trick using the Allen for leverage! Looks a lot like a copy…
Thanks! Dave D.
David Dryden - Reply Share
Not really clear in what mode it needs to be, nor what rotation mode
Rombout Versluijs - Reply Share
1st gear and twist the drill threshold to the drill bit setting (max torque).
Dustin Gordon - Reply Share
Past 24 Hours: 7
Past 7 Days: 42
Past 30 Days: 183
All Time: 23,705
