Milwaukee M12 2457-20 Disassembly
Views: 3.4K
View statistics:
Past 24 Hours:
6
Past 7 Days:
44
Past 30 Days:
238
All Time:
3,393
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 10 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
This guide will show you how to disassemble the Milwaukee M12 Cordless 3/8" Ratchet to access various parts for replacement or repairs.
Tools
    1. Milwaukee M12 2457-20 Disassembly, Housing: step 1, image 1 of 2 Milwaukee M12 2457-20 Disassembly, Housing: step 1, image 2 of 2
      • Unscrew the four M3 x 10 T-10 screws located on the neck.
      Ask FixBot
    2. Milwaukee M12 2457-20 Disassembly: step 2, image 1 of 2 Milwaukee M12 2457-20 Disassembly: step 2, image 2 of 2
      • Remove the spring pin from the switch paddle and take off the switch paddle.
      Ask FixBot
    3. Milwaukee M12 2457-20 Disassembly: step 3, image 1 of 1
      • Unscrew the four M2.6 x 14 ST T-8 screws located on the body.
      • Unscrew the M2.6 x 10 ST T-8 screw located underneath the switch paddle.
      Ask FixBot
    4. Milwaukee M12 2457-20 Disassembly: step 4, image 1 of 2 Milwaukee M12 2457-20 Disassembly: step 4, image 2 of 2
      • Separate the two housing parts of the tool.
      • Remove the 3/8" yoke assembly and the motor assembly from the tool housing.
      Ask FixBot
    5. Milwaukee M12 2457-20 Disassembly: step 5, image 1 of 2 Milwaukee M12 2457-20 Disassembly: step 5, image 2 of 2
      • Remove the drive pin connecting the 3/8" yoke assembly and the motor assembly.
      • Remove the crankshaft, planet gears, carrier assembly, and ring gear from the motor assembly.
      • Be aware that these parts are lubricated with grease.
      Ask FixBot
    6. Milwaukee M12 2457-20 Disassembly: step 6, image 1 of 1
      • You have now successfully dismantled the device.
      Ask FixBot
Peter Lizotte
183 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 6
Past 7 Days: 44
Past 30 Days: 238
All Time: 3,393
