Milwaukee Hex Impact Driver 2656-20 Trigger Assembly Replacement
  1. Milwaukee Hex Impact Driver 2656-20 Trigger Assembly  Replacement, Battery: step 1, image 1 of 2 Milwaukee Hex Impact Driver 2656-20 Trigger Assembly  Replacement, Battery: step 1, image 2 of 2
    • Squeeze the red buttons on the battery.
    • While squeezing the red buttons, slide the battery forward and out to remove it from the device.
    Ask FixBot
  2. Milwaukee Hex Impact Driver 2656-20 Trigger Assembly  Replacement, Milwaukee Hex Impact Driver 2656-20 Case  Disassembly: step 2, image 1 of 2 Milwaukee Hex Impact Driver 2656-20 Trigger Assembly  Replacement, Milwaukee Hex Impact Driver 2656-20 Case  Disassembly: step 2, image 2 of 2
    • Lay the impact driver on its side.
    • Remove eight 16 mm and a single 19 mm screws using the T10 Torx Screwdriver.
    • Separate the two halves by pulling up on the top half.
    • Make sure that the half with the screw heads Is facing up during this process. This will ensure that the components do not fall out.
    • Lay the top half to the side.
    Ask FixBot
  3. Milwaukee Hex Impact Driver 2656-20 Trigger Assembly  Replacement, Trigger Assembly: step 3, image 1 of 2 Milwaukee Hex Impact Driver 2656-20 Trigger Assembly  Replacement, Trigger Assembly: step 3, image 2 of 2
    • Remove the two 6 mm screws on the back of the brush card assembly using the T10 Torx screwdriver.
    • Move the two wires out of the way.
    Ask FixBot
  4. Milwaukee Hex Impact Driver 2656-20 Trigger Assembly  Replacement: step 4, image 1 of 2 Milwaukee Hex Impact Driver 2656-20 Trigger Assembly  Replacement: step 4, image 2 of 2
    • Gently pull up on the trigger assembly to remove it from the case.
    Ask FixBot
  5. Milwaukee Hex Impact Driver 2656-20 Trigger Assembly  Replacement: step 5, image 1 of 1
    • Remove the trigger assembly from the device.
    Ask FixBot
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 6
Past 30 Days: 34
All Time: 1,757
