Milwaukee Hex Impact Driver 2656-20 Case Disassembly
    1. Milwaukee Hex Impact Driver 2656-20 Case  Disassembly, Battery: step 1, image 1 of 2 Milwaukee Hex Impact Driver 2656-20 Case  Disassembly, Battery: step 1, image 2 of 2
      • Squeeze the red buttons on the battery.
      • While squeezing the red buttons, slide the battery forward and out to remove it from the device.
      Ask FixBot
    1. Milwaukee Hex Impact Driver 2656-20 Case  Disassembly, Milwaukee Hex Impact Driver 2656-20 Case  Disassembly: step 2, image 1 of 2 Milwaukee Hex Impact Driver 2656-20 Case  Disassembly, Milwaukee Hex Impact Driver 2656-20 Case  Disassembly: step 2, image 2 of 2
      • Lay the impact driver on its side.
      • Remove eight 16 mm and a single 19 mm screws using the T10 Torx Screwdriver.
      • Separate the two halves by pulling up on the top half.
      • Make sure that the half with the screw heads Is facing up during this process. This will ensure that the components do not fall out.
      • Lay the top half to the side.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 17
Past 30 Days: 58
All Time: 3,134
