Introduction
If your Milwaukee (6130-33) makes screeching or unusual noises, this guide will provide the steps to replace the gearing system. You will need a TR 20 screwdriver, a TR 10, a 6mm flathead screwdriver, and a metal spudger for access.
Once the gears are accessed, use a rag remove any slimy substance to inspect the interior and exterior of the gear system. Check for debris and build-up, as the gears are a common place for debris due to usage.
Along with checking the gear system, check that all screws are secured correctly. The interior of the casing is a part of the direct control to the Cut-Off Wheel functioning. Inspect both components thoroughly when testing before testing the device.
Position the cut-off wheel so that is facing upward.
Remove the top flange nut by turning it counterclockwise.
Pull the flange upward from the spindle to remove it.
