Milwaukee 6130-33 Cut-Off Wheel Replacement
  1. Milwaukee 6130-33 Cut-Off Wheel Replacement, Cut-Off Wheel: step 1, image 1 of 3 Milwaukee 6130-33 Cut-Off Wheel Replacement, Cut-Off Wheel: step 1, image 2 of 3 Milwaukee 6130-33 Cut-Off Wheel Replacement, Cut-Off Wheel: step 1, image 3 of 3
    • Position the cut-off wheel so that is facing upward.
    • Remove the top flange nut by turning it counterclockwise.
    • If a disc replacement is necessary, you will find the disc located beneath the top flange nut.
    • Pull the flange upward from the spindle to remove it.
    Ask FixBot
  2. Milwaukee 6130-33 Cut-Off Wheel Replacement: step 2, image 1 of 2 Milwaukee 6130-33 Cut-Off Wheel Replacement: step 2, image 2 of 2
    • Press down on the detent tab to release the guard lock.
    • Remove guard from detent tab.
    • Gently wiggle when remove from left to right before pulling up.
    Ask FixBot
  3. Milwaukee 6130-33 Cut-Off Wheel Replacement: step 3, image 1 of 3 Milwaukee 6130-33 Cut-Off Wheel Replacement: step 3, image 2 of 3 Milwaukee 6130-33 Cut-Off Wheel Replacement: step 3, image 3 of 3
    • Remove the 3 mm Phillips #1 screw that secures the detent tab.
    Ask FixBot
  4. Milwaukee 6130-33 Cut-Off Wheel Replacement: step 4, image 1 of 2 Milwaukee 6130-33 Cut-Off Wheel Replacement: step 4, image 2 of 2
    • Push down on top of detent tab, then remove detent tab by pulling upwards.
    Ask FixBot
  5. Milwaukee 6130-33 Cut-Off Wheel Replacement: step 5, image 1 of 3 Milwaukee 6130-33 Cut-Off Wheel Replacement: step 5, image 2 of 3 Milwaukee 6130-33 Cut-Off Wheel Replacement: step 5, image 3 of 3
    • Remove the spring between the two top corner screws.
    Ask FixBot
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 8
Past 30 Days: 31
All Time: 351
