Milwaukee 5262-21 Fan Baffle Replacement
    1. Milwaukee 5262-21 Fan Baffle Replacement, Housing Assembly: step 1, image 1 of 1
      • Remove the ten 19mm T20 Torx screws shown in red.
      Ask FixBot
    2. Milwaukee 5262-21 Fan Baffle Replacement: step 2, image 1 of 1
      • Remove the red Housing Assembly by lifting it up off of the tool.
      Ask FixBot
    1. Milwaukee 5262-21 Fan Baffle Replacement, Fan Baffle: step 3, image 1 of 2 Milwaukee 5262-21 Fan Baffle Replacement, Fan Baffle: step 3, image 2 of 2
      • Now the two 10mm T-10 screws shown in red can be removed.
      • Next, remove the two 10mm T-10 screws located on the other side of the tool shown in orange.
      Ask FixBot
    2. Milwaukee 5262-21 Fan Baffle Replacement: step 4, image 1 of 2 Milwaukee 5262-21 Fan Baffle Replacement: step 4, image 2 of 2
      • Using the metal spudger, remove each brush holder as shown in the images.
      Ask FixBot
    3. Milwaukee 5262-21 Fan Baffle Replacement: step 5, image 1 of 3 Milwaukee 5262-21 Fan Baffle Replacement: step 5, image 2 of 3 Milwaukee 5262-21 Fan Baffle Replacement: step 5, image 3 of 3
      • Remove the four 37mm T-20 screws shown in red. These screws attach the gear housing to the motor housing.
      Ask FixBot
    4. Milwaukee 5262-21 Fan Baffle Replacement: step 6, image 1 of 2 Milwaukee 5262-21 Fan Baffle Replacement: step 6, image 2 of 2
      • After removing the four screws, pull apart the the two sections.
      Ask FixBot
    5. Milwaukee 5262-21 Fan Baffle Replacement: step 7, image 1 of 2 Milwaukee 5262-21 Fan Baffle Replacement: step 7, image 2 of 2
      • Remove the four 12mm screws with a T-15 Torx screwdriver shown in red.
      • These screws hold the fan baffle in place.
      Ask FixBot
    6. Milwaukee 5262-21 Fan Baffle Replacement: step 8, image 1 of 2 Milwaukee 5262-21 Fan Baffle Replacement: step 8, image 2 of 2
      • Remove the fan baffle by pulling it out.
      Ask FixBot
Andrew Floyd
277 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 8
Past 30 Days: 25
All Time: 889
