Milwaukee 2780-20 Trigger Assembly Replacement
  1. Milwaukee 2780-20 Trigger Assembly Replacement, Trigger Assembly: step 1, image 1 of 3 Milwaukee 2780-20 Trigger Assembly Replacement, Trigger Assembly: step 1, image 2 of 3 Milwaukee 2780-20 Trigger Assembly Replacement, Trigger Assembly: step 1, image 3 of 3
    • Using a Torx T20 screwdriver, unscrew the four 16mm screws from the case.
    • Switch to the Torx T10 screwdriver, and remove the last 16mm screw from the hilt.
    Ask FixBot
  2. Milwaukee 2780-20 Trigger Assembly Replacement: step 2, image 1 of 3 Milwaukee 2780-20 Trigger Assembly Replacement: step 2, image 2 of 3 Milwaukee 2780-20 Trigger Assembly Replacement: step 2, image 3 of 3
    • Using the Torx T20 screwdriver, unscrew the four 28mm screws located at the bottom (and top) of the gearcase assembly.
    • Remove the two 12mm screws with a Torx T20 screwdriver in order to get to the others.
    Ask FixBot
  3. Milwaukee 2780-20 Trigger Assembly Replacement: step 3, image 1 of 1
    • Pull apart the housing handles.
    Ask FixBot
  4. Milwaukee 2780-20 Trigger Assembly Replacement: step 4, image 1 of 3 Milwaukee 2780-20 Trigger Assembly Replacement: step 4, image 2 of 3 Milwaukee 2780-20 Trigger Assembly Replacement: step 4, image 3 of 3
    • Lift the trigger assembly off of its mount.
    • Dispose of the old trigger assembly and install the new one.
    Ask FixBot
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 50
All Time: 1,796
