Milwaukee 2780-20 Rotor Assembly Replacement
  1. Milwaukee 2780-20 Rotor Assembly Replacement, Trigger Assembly: step 1, image 1 of 3 Milwaukee 2780-20 Rotor Assembly Replacement, Trigger Assembly: step 1, image 2 of 3 Milwaukee 2780-20 Rotor Assembly Replacement, Trigger Assembly: step 1, image 3 of 3
    • Using a Torx T20 screwdriver, unscrew the four 16mm screws from the case.
    • Switch to the Torx T10 screwdriver, and remove the last 16mm screw from the hilt.
    Ask FixBot
  2. Milwaukee 2780-20 Rotor Assembly Replacement: step 2, image 1 of 3 Milwaukee 2780-20 Rotor Assembly Replacement: step 2, image 2 of 3 Milwaukee 2780-20 Rotor Assembly Replacement: step 2, image 3 of 3
    • Using the Torx T20 screwdriver, unscrew the four 28mm screws located at the bottom (and top) of the gearcase assembly.
    • Remove the two 12mm screws with a Torx T20 screwdriver in order to get to the others.
    Ask FixBot
  3. Milwaukee 2780-20 Rotor Assembly Replacement: step 3, image 1 of 1
    • Pull apart the housing handles.
    Ask FixBot
  4. Milwaukee 2780-20 Rotor Assembly Replacement: step 4, image 1 of 3 Milwaukee 2780-20 Rotor Assembly Replacement: step 4, image 2 of 3 Milwaukee 2780-20 Rotor Assembly Replacement: step 4, image 3 of 3
    • Lift the trigger assembly off of its mount.
    • Dispose of the old trigger assembly and install the new one.
    Ask FixBot
  5. Milwaukee 2780-20 Rotor Assembly Replacement, Rotor Assembly: step 5, image 1 of 3 Milwaukee 2780-20 Rotor Assembly Replacement, Rotor Assembly: step 5, image 2 of 3 Milwaukee 2780-20 Rotor Assembly Replacement, Rotor Assembly: step 5, image 3 of 3
    • Using a Torx T20 screwdriver, unscrew the four 6mm screws located at the top of the gearcase assembly.
    • Pull apart the top of the gearcase assembly to expose the inside of it.
    Ask FixBot
  6. Milwaukee 2780-20 Rotor Assembly Replacement: step 6, image 1 of 2 Milwaukee 2780-20 Rotor Assembly Replacement: step 6, image 2 of 2
    • Pull the Gearcase Assembly away from the electronic kit.
    Ask FixBot
  7. Milwaukee 2780-20 Rotor Assembly Replacement: step 7, image 1 of 2 Milwaukee 2780-20 Rotor Assembly Replacement: step 7, image 2 of 2
    • Using a 3/8 wrench, remove the nut located in the center of the Gearcase.
    • The nut and pinion will immediately come apart from the Rotor assembly.
    Ask FixBot
  8. Milwaukee 2780-20 Rotor Assembly Replacement: step 8, image 1 of 3 Milwaukee 2780-20 Rotor Assembly Replacement: step 8, image 2 of 3 Milwaukee 2780-20 Rotor Assembly Replacement: step 8, image 3 of 3
    • Pull the rotor assembly away from the gearcase assembly.
    Ask FixBot
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 25
All Time: 1,316
