Milwaukee 2704-20 Trigger Replacement
    1. Milwaukee 2704-20 Trigger Replacement, Outer Case: step 1, image 1 of 2 Milwaukee 2704-20 Trigger Replacement, Outer Case: step 1, image 2 of 2
      • Remove the battery from the drill.
      Ask FixBot
    2. Milwaukee 2704-20 Trigger Replacement: step 2, image 1 of 3 Milwaukee 2704-20 Trigger Replacement: step 2, image 2 of 3 Milwaukee 2704-20 Trigger Replacement: step 2, image 3 of 3
      • Remove the indicated screws (M3 x 16mm Pan Hd. ST T-10 Screws) with screwdriver.
      Ask FixBot
    3. Milwaukee 2704-20 Trigger Replacement: step 3, image 1 of 3 Milwaukee 2704-20 Trigger Replacement: step 3, image 2 of 3 Milwaukee 2704-20 Trigger Replacement: step 3, image 3 of 3
      • Gently lift the cover off the drill. Be careful not to force it or damage any of the internal components.
      • If the cover doesn't come off easily, check for any clips or latches that may be holding it in place. These can usually be released by pressing them with a small flathead screwdriver.
      Ask FixBot
    1. Milwaukee 2704-20 Trigger Replacement, Trigger: step 4, image 1 of 2 Milwaukee 2704-20 Trigger Replacement, Trigger: step 4, image 2 of 2
      • Desolder the two solder joints on the trigger assembly.
      • USE CAUTION! Soldering irons get extremely hot, as will everything they make prolonged contact with.
      Ask FixBot
    2. Milwaukee 2704-20 Trigger Replacement: step 5, image 1 of 2 Milwaukee 2704-20 Trigger Replacement: step 5, image 2 of 2
      Tool used on this step:
      Buy
      • Using tweezers, remove the header connector.
      • To avoid damage, be careful replicating this step in both the removal and replacement processes.
      Ask FixBot
    3. Milwaukee 2704-20 Trigger Replacement: step 6, image 1 of 1
      • Remove the trigger mechanism entirely.
      Ask FixBot
Brandon Farquharson
159 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 15
Past 30 Days: 58
All Time: 1,236
