Milwaukee 2704-20 Outer Case Replacement
  1. Milwaukee 2704-20 Outer Case Replacement, Outer Case: step 1, image 1 of 2 Milwaukee 2704-20 Outer Case Replacement, Outer Case: step 1, image 2 of 2
    • Remove the battery from the drill.
    Ask FixBot
  2. Milwaukee 2704-20 Outer Case Replacement: step 2, image 1 of 3 Milwaukee 2704-20 Outer Case Replacement: step 2, image 2 of 3 Milwaukee 2704-20 Outer Case Replacement: step 2, image 3 of 3
    • Remove the indicated screws (M3 x 16mm Pan Hd. ST T-10 Screws) with screwdriver.
    Ask FixBot
  3. Milwaukee 2704-20 Outer Case Replacement: step 3, image 1 of 3 Milwaukee 2704-20 Outer Case Replacement: step 3, image 2 of 3 Milwaukee 2704-20 Outer Case Replacement: step 3, image 3 of 3
    • Gently lift the cover off the drill. Be careful not to force it or damage any of the internal components.
    • If the cover doesn't come off easily, check for any clips or latches that may be holding it in place. These can usually be released by pressing them with a small flathead screwdriver.
    Ask FixBot
Unique Linnell
429 Reputation
5 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 20
All Time: 338
