Miele W4164 disassembly
Views: 13K
View statistics:
Past 24 Hours:
18
Past 7 Days:
85
Past 30 Days:
323
All Time:
12,742
Comments: 15
10 comments on steps, 5 guide comments.
Go to guide comments
Completed: 7
7 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 45 minutes - 1 hour
Difficulty: Moderate
Community-Contributed Guide
    1. Miele W4164 disassembly, Miele W4164 disassembly: step 1, image 1 of 1
      • The detergent drawer is removed, push down the yellow lever to remove it completely.
      Ask FixBot
    2. Miele W4164 disassembly: step 2, image 1 of 1
      • The lid has a small panel on both sides that can be levered out with a small screwdriver.
      Ask FixBot
    3. Miele W4164 disassembly: step 3, image 1 of 1
      • There is a Tx20 screw under each of these covers, remove this.
      Ask FixBot
    4. Miele W4164 disassembly: step 4, image 1 of 1
      • The cover can now be lifted at the front and then pushed back slightly. At the rear end it is only slightly hooked.
      Ask FixBot
      • The left side panel has three clearly visible screws at the top and three at the back, all Tx20. These must be removed. Caution, the three screws above are only identical to the bottom screw at the back, the other two screws from the back are different.
      • Caution, the side panel cannot be removed yet, in this step only loosen the screws.
      Ask FixBot
    5. Miele W4164 disassembly: step 6, image 1 of 1
      • Remove the two Tx20 screws from the door lock.
      Ask FixBot
    6. Miele W4164 disassembly: step 7, image 1 of 1
      • Remove the Tx30 screw below the filler hole.
      Ask FixBot
    7. Miele W4164 disassembly: step 8, image 1 of 1
      • Lift the cover of the control bar slightly from behind and remove it.
      Ask FixBot
    8. Miele W4164 disassembly: step 9, image 1 of 1
      • The control panel is secured with one screw on the right side, remove this Tx20 screw.
      • Do not remove any other screws from here.
      Ask FixBot
    9. Miele W4164 disassembly: step 10, image 1 of 2 Miele W4164 disassembly: step 10, image 2 of 2
      • The control unit is hooked into two places, one to the right of the detergent drawer and one to the far right.
      • Carefully loosen the unit there, it is still connected with cables, so place the unit carefully on the machine.
      Ask FixBot
    10. Miele W4164 disassembly: step 11, image 1 of 2 Miele W4164 disassembly: step 11, image 2 of 2
      • The front is still attached with two Tx20 screws on the right and left, loosen them while holding the front so that it doesn't accidentally fall down and get damaged. The front has a small hold on the right screw through the metal bracket.
      Ask FixBot
    11. Miele W4164 disassembly: step 12, image 1 of 1
      • The front front is hooked to small feet, lift slightly to release. Make sure that the damper rubber remains on the feet. The front is still connected to the machine via the rubber boot. Keep holding the front.
      Ask FixBot
    12. Miele W4164 disassembly: step 13, image 1 of 3 Miele W4164 disassembly: step 13, image 2 of 3 Miele W4164 disassembly: step 13, image 3 of 3
      • Now move the front a bit so that you can loosen the 3 Tx20 screws on the left front. Then reinsert the front panel and fix it with the two upper screws. The left front can now be removed. Attention when installing the left front later, it will be hooked in at the lower end.
      • Be careful when installing the left side cover later, it will be slightly hooked at the lower end.
      Ask FixBot
      • If the machine is to be operated while it is open, the door lock must be fastened first. The screw underneath the door collar has to be fastened as well.
      Ask FixBot
Work the steps in reverse order to reassemble your device.
7 other people completed this guide.
Special thanks to these translators:
de en
100%
oldturkey03 is helping us fix the world! Want to contribute?
Start translating ›
kapott
3,128 Reputation
14 Guides authored
5 Guide Comments
Vielen Dank an kapott für das Verfassen des Artikels. Ohne diese Anleitung hätte ich ziemliche Bedenken bei der Demontage gehabt, da man nie weiß, ob man eine Klammer oder ein Kabel abreißt.
Andi Andi - Reply Share
Vielen Dank!
Patrick Schmidt - Reply Share
Sehr gute Erlärung, vielen Dank!
Bei dieser Maschine wurde leider viel zu lange mit dem Tausch der Stoßdämpfer gewartet und deshalb hat eine scharfe Kante vom Bottich die Rücklaufsperre vom Abwasser beschädigt. Ärgerlich, da das Teil teuer ist!
Hartmut Suhr - Reply Share
Ich bräuchte bitte nochmal Hilfe: Leider hat es sehr lange, bis jetzt, gedauert bis ich alle erforderlichen Ersatzteile zusammen hatte. Und nun habe ich blöderweise (die berühmte) eine Schraube übrig. Das ärgert mich! Kann mir bitte jemand sagen wo die hingehört? Torx 20 mit fester Unterlegscheibe und für Kunststoffgewinde, insgesamt 15 mm lang. Da sie sehr sauber ist, muss sie irgendwo verdeckt sitzen, aber ich finde nicht wo.
Ach ich Esel, Problem gelöst! Diese übrig gebliebenen Schraube gehörte zu dem gebraucht gekauften Rückflussverhinderer und ist somit doppelt vorhanden bzw überflüssig.
Guten Rutsch und langes Leben für die Mieles.
Past 24 Hours: 18
Past 7 Days: 85
Past 30 Days: 323
All Time: 12,742
