This translation was generated by a machine and has not been reviewed by a person yet. Speak this language? Review it.
Miele S8340 Repair
View statistics:
Past 24 Hours:
Past 7 Days:
6
Past 30 Days:
6
All Time:
6
Comments: 5
5 comments on steps.
Completed: 0
Favorites: 0
Time Required: 30 minutes
Difficulty: Moderate
Community-Contributed Guide
Miele S8340 Repair
Introduction
Go to step 1 ↓
The Miele S8340 was presented at a Repair Café with the current fault description: "Motor not running, MAX light permanently on."
Tools
  • Tx20 Torx Schraubendreher
    Der iFixit-Bithalter ist nicht lang genug für eine der Schrauben
  • Spudger
    4.9
    Alternativ kann auch ein Schlitzschraubendreher oder Ähnliches verwendet werden
    1. Miele S8340 Repair, Miele S8340 Vacuum cleaner: step 1, image 1 of 2 Miele S8340 Repair, Miele S8340 Vacuum cleaner: step 1, image 2 of 2
      • Open the vacuum and take out the dust bag.
      Ask FixBot
    2. Miele S8340 Repair: step 2, image 1 of 2 Miele S8340 Repair: step 2, image 2 of 2
      • Take out the filter.
      • Remove the screws.
      Ask FixBot
    3. Miele S8340 Repair: step 3, image 1 of 2 Miele S8340 Repair: step 3, image 2 of 2
      • Slide a flat object (like a flat head screwdriver or the spudger) underneath the buttons to remove them.
      • Remove the screws. For the left screw, you will need a screwdriver, an extension or something similar (the iFixit bit driver is not long enough).
      Ask FixBot
    4. Miele S8340 Repair: step 4, image 1 of 3 Miele S8340 Repair: step 4, image 2 of 3 Miele S8340 Repair: step 4, image 3 of 3
      • The white cover and the black "ribbon" are secured with clips. To remove them, you first insert a spudger between the cover and the vacuum itself (picture 1). Then you can insert a spudger between the ribbon and the vacuum and slide it around the whole vacuum to detach the ribbon from the machine.
      Ask FixBot
    5. Miele S8340 Repair: step 5, image 1 of 3 Miele S8340 Repair: step 5, image 2 of 3 Miele S8340 Repair: step 5, image 3 of 3
      • The white cover should now also be detached from the black ribbon.
      • To remove the cover, you need to slightly bend it outwards and then slide it over the hinge.
      • Be careful so you don't snap the cover.
      • After that you can remove the black ribbon.
      Ask FixBot
    6. Miele S8340 Repair: step 6, image 1 of 1
      • The remove the vacuum pipe hooks you can remove this screw on both sides.
      Ask FixBot
    7. Miele S8340 Repair: step 7, image 1 of 1
      • Next you will need to remove this screw, located left side of the motor
      Ask FixBot
    8. Miele S8340 Repair: step 8, image 1 of 3 Miele S8340 Repair: step 8, image 2 of 3 Miele S8340 Repair: step 8, image 3 of 3
      • Now you can remove the whole rear part of the vacuum, together with the flap. You might need to pull on multiple places and use a bit of force.
      • After that part is removed there will be exposed live contacts. Definitely make sure that your vacuum is unplugged!
      • Now you can remove the plug from the motor and subsequently simply pull out the motor and the cable spool upwards. Make sure that you don't rip off any cables or connectors!
      Ask FixBot
    9. Miele S8340 Repair: step 9, image 1 of 1
      • Then you can simply remove the black cover from the rear part of the vacuum by sliding it downwards.
      Ask FixBot
    10. Miele S8340 Repair: step 10, image 1 of 3 Miele S8340 Repair: step 10, image 2 of 3 Miele S8340 Repair: step 10, image 3 of 3
      • Open this (and possibly further) clip on the rear part of the vacuum.
      • Then you can detach the part that contains the electronics from the flap.
      • This part houses the electronics. If you flip it around you can remove the circuit board easily.
      Ask FixBot
The usual fault with stuck carbon brushes was not the cause in this case.
The next suspect, the triac, was also measured and found to be in working order.
In fact, one of the connection legs of the Klixon bimetal switch was broken.
Until a replacement part became available, the leg was replaced and soldered.
Repair successful.
Sepp
1 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 6
All Time: 6
