Up to 20% off select tools
Mid F900 Microphone Replacement
View statistics:
Past 24 Hours:
2
Past 7 Days:
15
Past 30 Days:
90
All Time:
639
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
This is a guide to replace the microphone in the device. Make sure to follow all the steps correctly and handle with care.
    1. Mid F900 Microphone Replacement, Back Cover: step 1, image 1 of 1
      • Using a J00 Phillips-head screwdriver, remove the two screws located at the bottom of the device.
      • Screws are 5mm x 1mm in size.
      Ask FixBot
    2. Mid F900 Microphone Replacement: step 2, image 1 of 2 Mid F900 Microphone Replacement: step 2, image 2 of 2
      • Use the plastic opening tool to pry off the white back-plate of the device.
      Ask FixBot
    1. Mid F900 Microphone Replacement, Motherboard: step 3, image 1 of 2 Mid F900 Microphone Replacement, Motherboard: step 3, image 2 of 2
      • Using a +00 Phillips head screwdriver, remove the screws securing the motherboard to the device housing.
      • Screws are 4mm x 1mm in size.
      Ask FixBot
    2. Mid F900 Microphone Replacement: step 4, image 1 of 2 Mid F900 Microphone Replacement: step 4, image 2 of 2
      • Desolder the two black and red wires connected to the motherboard.
      • Unclip and remove the ribbon cables attached to the motherboard.
      • For soldering help, use the How to Solder and Desolder Connections guide.
      Ask FixBot
    3. Mid F900 Microphone Replacement: step 5, image 1 of 2 Mid F900 Microphone Replacement: step 5, image 2 of 2
      • Carefully lift and remove the motherboard from the device housing.
      Ask FixBot
    1. Mid F900 Microphone Replacement, Microphone: step 6, image 1 of 1
      • Flip the motherboard over to bring the underside into view.
      • Find and desolder the microphone near the bottom of the motherboard and remove it.
      • Solder the new microphone in its place.
      • For soldering help, check out the How to Solder and Desolder Connections guide.
      Ask FixBot
Author
with
Matthew Oliva
364 Reputation
3 Guides authored
USF Tampa, Team 6-6, Remmell Fall 2016 Member of USF Tampa, Team 6-6, Remmell Fall 2016
USFT-REMMELL-F16S6G6
3 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 15
Past 30 Days: 90
All Time: 639
