Microtek ScanMaker 5900 New Upper Lid Bulbs Replacement
  1. Microtek ScanMaker 5900 New Upper Lid Bulbs Replacement, Remove serial port connection: step 1, image 1 of 3 Microtek ScanMaker 5900 New Upper Lid Bulbs Replacement, Remove serial port connection: step 1, image 2 of 3 Microtek ScanMaker 5900 New Upper Lid Bulbs Replacement, Remove serial port connection: step 1, image 3 of 3
    • Loosen the screws on the serial port by turning them counter clockwise by hand.
    • After loosening the screws, pull the serial port out.
    Ask FixBot
  2. Microtek ScanMaker 5900 New Upper Lid Bulbs Replacement, Remove Lid: step 2, image 1 of 3 Microtek ScanMaker 5900 New Upper Lid Bulbs Replacement, Remove Lid: step 2, image 2 of 3 Microtek ScanMaker 5900 New Upper Lid Bulbs Replacement, Remove Lid: step 2, image 3 of 3
    • Lift lid to its vertical position.
    • Pull lid straight up to remove it from the scanner.
    Ask FixBot
  3. Microtek ScanMaker 5900 New Upper Lid Bulbs Replacement, Remove the protective plastic covering: step 3, image 1 of 3 Microtek ScanMaker 5900 New Upper Lid Bulbs Replacement, Remove the protective plastic covering: step 3, image 2 of 3 Microtek ScanMaker 5900 New Upper Lid Bulbs Replacement, Remove the protective plastic covering: step 3, image 3 of 3
    Tool used on this step:
    Buy
    • Notice that there are two plastic tabs that need to be pushed in to remove the plastic covering.
    • Use tweezers to push these tabs in.
    • Gently pull the plastic covering off of the upper lid.
    Ask FixBot
  4. Microtek ScanMaker 5900 New Upper Lid Bulbs Replacement, Remove wires from circuit board: step 4, image 1 of 3 Microtek ScanMaker 5900 New Upper Lid Bulbs Replacement, Remove wires from circuit board: step 4, image 2 of 3 Microtek ScanMaker 5900 New Upper Lid Bulbs Replacement, Remove wires from circuit board: step 4, image 3 of 3
    • Grab the plastic wire housing near the serial port.
    • Gently pull and jiggle the wire housing until it comes free from the circuit board.
    Ask FixBot
  5. Microtek ScanMaker 5900 New Upper Lid Bulbs Replacement, Remove the bulbs: step 5, image 1 of 2 Microtek ScanMaker 5900 New Upper Lid Bulbs Replacement, Remove the bulbs: step 5, image 2 of 2
    • Gently lift up the bulbs and remove the wires from the plastic.
    • After completely freeing the bulbs, buy new ones and replace.
    Ask FixBot
Taylor Nesheim
59 Reputation
7 Guides authored
Cal Poly, Team 6-9, Regan Fall 2011 Member of Cal Poly, Team 6-9, Regan Fall 2011
CPSU-REGAN-F11S6G9
2 Members
22 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 7
Past 30 Days: 31
All Time: 1,516
