Up to 20% off select tools
Microtek ScanMaker 5900 New Locking Mechanism Replacement
Views: 2.1K
View statistics:
Past 24 Hours:
4
Past 7 Days:
20
Past 30 Days:
95
All Time:
2,078
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 5 - 10 minutes
Difficulty: Moderate
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Tools
Introduction
Go to step 1 ↓
This guide shows the owner of the device how to take and replace the locking mechanism for the scanner.
    1. Microtek ScanMaker 5900 New Locking Mechanism Replacement, Remove serial port connection: step 1, image 1 of 3 Microtek ScanMaker 5900 New Locking Mechanism Replacement, Remove serial port connection: step 1, image 2 of 3 Microtek ScanMaker 5900 New Locking Mechanism Replacement, Remove serial port connection: step 1, image 3 of 3
      • Loosen the screws on the serial port by turning them counter clockwise by hand.
      • After loosening the screws, pull the serial port out.
      Ask FixBot
    2. Microtek ScanMaker 5900 New Locking Mechanism Replacement, Remove Lid: step 2, image 1 of 3 Microtek ScanMaker 5900 New Locking Mechanism Replacement, Remove Lid: step 2, image 2 of 3 Microtek ScanMaker 5900 New Locking Mechanism Replacement, Remove Lid: step 2, image 3 of 3
      • Lift lid to its vertical position.
      • Pull lid straight up to remove it from the scanner.
      Ask FixBot
    1. Microtek ScanMaker 5900 New Locking Mechanism Replacement, Detach plastic latches: step 3, image 1 of 3 Microtek ScanMaker 5900 New Locking Mechanism Replacement, Detach plastic latches: step 3, image 2 of 3 Microtek ScanMaker 5900 New Locking Mechanism Replacement, Detach plastic latches: step 3, image 3 of 3
      • Push the plastic opening tools into the crack between the top and the bottom of the chassis.
      Ask FixBot
    2. Microtek ScanMaker 5900 New Locking Mechanism Replacement, Continue latch detachment: step 4, image 1 of 3 Microtek ScanMaker 5900 New Locking Mechanism Replacement, Continue latch detachment: step 4, image 2 of 3 Microtek ScanMaker 5900 New Locking Mechanism Replacement, Continue latch detachment: step 4, image 3 of 3
      • After placing one plastic opening tool into the slit, slide other plastic opening tools along the slit to detach the top from the bottom of the chassis.
      • Go all the way along the chassis until you can lift the upper lid.
      Ask FixBot
    3. Microtek ScanMaker 5900 New Locking Mechanism Replacement, Fully remove the upper lid: step 5, image 1 of 3 Microtek ScanMaker 5900 New Locking Mechanism Replacement, Fully remove the upper lid: step 5, image 2 of 3 Microtek ScanMaker 5900 New Locking Mechanism Replacement, Fully remove the upper lid: step 5, image 3 of 3
      • Do not fully remove the lid until you remove the ribbon cable attached to the front of the upper lid.
      • Do this by grabbing the upper lid from the sides and rotating it ninety degrees so it is perpendicular to the bottom lid.
      • Grab the ribbon cable and gently pull it out of its slot with your fingers.
      • The upper lid can now safely be removed from the bottom lid.
      Ask FixBot
    1. Microtek ScanMaker 5900 New Locking Mechanism Replacement, Remove locking mechanism: step 6, image 1 of 3 Microtek ScanMaker 5900 New Locking Mechanism Replacement, Remove locking mechanism: step 6, image 2 of 3 Microtek ScanMaker 5900 New Locking Mechanism Replacement, Remove locking mechanism: step 6, image 3 of 3
      • Locate the locking mechanism in the front left hand corner of the device.
      • Gently push on it until it becomes loose.
      • Rotate and jiggle it until it comes out the bottom of the scanner.
      • Find a replacement locking mechanism and insert it into the scanner.
      Ask FixBot
Author
with
Taylor Nesheim
59 Reputation
7 Guides authored
Cal Poly, Team 6-9, Regan Fall 2011 Member of Cal Poly, Team 6-9, Regan Fall 2011
CPSU-REGAN-F11S6G9
2 Members
132 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 20
Past 30 Days: 95
All Time: 2,078
