Microsoft Zune HD Lower Rear Panel Replacement
    1. Microsoft Zune HD Lower Rear Panel Replacement, Upper Rear Panel: step 1, image 1 of 1
      • Remove the four Tri-Wing screws securing the upper rear panel to the inner chassis.
      Ask FixBot
    2. Microsoft Zune HD Lower Rear Panel Replacement: step 2, image 1 of 2 Microsoft Zune HD Lower Rear Panel Replacement: step 2, image 2 of 2
      • Slightly rotate the top edge of the upper rear panel away from the Zune.
      • Lift the upper rear panel straight up off the black plastic lower rear panel.
      Ask FixBot
    1. Microsoft Zune HD Lower Rear Panel Replacement, Lower Rear Panel: step 3, image 1 of 2 Microsoft Zune HD Lower Rear Panel Replacement, Lower Rear Panel: step 3, image 2 of 2
      • Insert a small Zune opening tool into the gap between the logic board and one side of the black plastic lower rear panel.
      • Carefully twist the Zune opening tool to pop the lower rear panel off the clips attaching it to the Zune.
      • Repeat this process for the other side of the lower rear panel.
      Ask FixBot
    2. Microsoft Zune HD Lower Rear Panel Replacement: step 4, image 1 of 1
      • Carefully slide the lower rear panel away from the Zune.
      Ask FixBot
1 Guide Comment
I followed these instructions and now that lower cover will not snap back in place 😒
Robert Rank - Reply Share
Past 24 Hours: 2
Past 7 Days: 7
Past 30 Days: 34
All Time: 3,678
