Microsoft Zune HD Controls Sidebar Replacement
Views: 3.7K
View statistics:
Past 24 Hours:
Past 7 Days:
17
Past 30 Days:
95
All Time:
3,688
Comments: 1
1 guide comment.
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 2
2 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: No estimate
Difficulty: Moderate
Introduction
Go to step 1 ↓
Unable to raise or lower the volume? Replace the controls sidebar and restore balance to the force.
Tools
    1. Microsoft Zune HD Controls Sidebar Replacement, Upper Rear Panel: step 1, image 1 of 1
      • Remove the four Tri-Wing screws securing the upper rear panel to the inner chassis.
      Ask FixBot
    2. Microsoft Zune HD Controls Sidebar Replacement: step 2, image 1 of 2 Microsoft Zune HD Controls Sidebar Replacement: step 2, image 2 of 2
      • Slightly rotate the top edge of the upper rear panel away from the Zune.
      • Lift the upper rear panel straight up off the black plastic lower rear panel.
      Ask FixBot
    1. Microsoft Zune HD Controls Sidebar Replacement, Controls Sidebar: step 3, image 1 of 2 Microsoft Zune HD Controls Sidebar Replacement, Controls Sidebar: step 3, image 2 of 2
      • Use a Zune opening tool to gently lift the media button lever off the post cast into the inner chassis.
      • Try not excessively rotate the media button lever about this post.
      Ask FixBot
1 Guide Comment
Can the side panels (hello from Seattle) come off as well?
Evoke - Reply Share
Past 24 Hours: 1
Past 7 Days: 17
Past 30 Days: 95
All Time: 3,688
