Microsoft Zune 30 GB Battery Replacement
  1. Microsoft Zune 30 GB Battery Replacement, Back Case: step 1, image 1 of 2 Microsoft Zune 30 GB Battery Replacement, Back Case: step 1, image 2 of 2
    • Remove the plastic screw cover located on the bottom of the device. Insert a small flat-headed screwdriver into one side of the cover and gently ease it out. Repeat on the other side.
    • Be gentle when removing the screw cover as it is brittle and will break if forced.
    • You will need a #00 Phillips screwdriver to remove the two 2.6 mm screws that are exposed.
    Ask FixBot
  2. Microsoft Zune 30 GB Battery Replacement: step 2, image 1 of 1
    • Use the blue plastic opening tool to slowly work your way around the edges of the case, releasing the front plate from the bottom case.
    • Be gentle when prying the device open.
    Ask FixBot
  3. Microsoft Zune 30 GB Battery Replacement: step 3, image 1 of 2 Microsoft Zune 30 GB Battery Replacement: step 3, image 2 of 2
    • Turn the Zune over so the screen faces downward. This will ensure the battery does not fall out and pull on the cable.
    • The battery is not fastened to the inside of the case. It will fall out.
    • Pry up from the bottom of the Zune because the headphone jack will not allow you to remove the back case in one pull. You must slide the case up and away from the rest of the Zune.
    • The case is now separated. You can replace the case, if needed.
    Ask FixBot
  4. Microsoft Zune 30 GB Battery Replacement, Battery: step 4, image 1 of 2 Microsoft Zune 30 GB Battery Replacement, Battery: step 4, image 2 of 2
    • With the Zune facing down, as pictured, the battery ribbon cable is attached to the bottom right hand side of the logic board.
    • Use the small flat head screw driver to gently lift the brown clamp.
    • The clamp will release the battery ribbon cable from the logic board, freeing the battery.
    Ask FixBot
  5. Microsoft Zune 30 GB Battery Replacement: step 5, image 1 of 1
    • You can now replace the battery.
    • The battery is a Lithium ion 3.7 V.
    Ask FixBot
23 other people completed this guide.
jmorri04
350 Reputation
2 Guides authored
Cal Poly, Team 19-4, Maness Fall 2009 Member of Cal Poly, Team 19-4, Maness Fall 2009
CPSU-MANESS-F09S19G4
3 Members
4 Guides authored
2 Guide Comments
Someone please send a link for a new battery. Thanks
Earl - Reply Share
The last battery I took out had a little green corrosion on it. How do I clean the connector the battery is placed in? It's new and still want power on.
clyde parks - Reply Share
Past 24 Hours: 3
Past 7 Days: 30
Past 30 Days: 138
All Time: 20,581
