Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Introduction
Go to step 1 ↓Use this guide to replace the front and rear cameras in the Microsoft Surface Pro.
Use a heated iOpener or a heat gun to heat the edges of the display and soften its adhesive.
Apply a suction cup as close as possible to the edge of the display.
Use the suction cup to lift the edge of the display enough to insert an opening pick under the edge.
Slide the opening pick all the way around the edges of the display to cut through the adhesive on the bezel.
Ribbon cables and a circuit board are approx. 0.6 cm from the edge of the glass.
Starting from the top edge, lift the display slightly.
Before completely removing the display:
Disconnect the three display cables.
Gently peel from the frame 2 orange ribbon cables that are glued to it, as those should stay with the display. (e.g. use a thin plastic card to separate them)
Using a T5 Torx screwdriver, unscrew a total number of 23 screws located on the outside panel of the Surface Pro.
