Up to 20% off select tools
Microsoft Surface Pro Battery Replacement
Views: 274K
View statistics:
Past 24 Hours:
23
Past 7 Days:
199
Past 30 Days:
943
All Time:
274,218
Comments: 38
14 comments on steps, 24 guide comments.
Go to guide comments
Completed: 41
41 people have marked this guide "completed." Will you be next?
Favorites: 10
10 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 1 - 2 hours
Difficulty: Very difficult
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Parts
Tools
Introduction
Go to step 1 ↓
Use this guide to replace the battery pack in the Microsoft Surface Pro.
    1. Microsoft Surface Pro Battery Replacement, Heat edges of display: step 1, image 1 of 1
      • Use a heated iOpener or a heat gun to heat the edges of the display and soften its adhesive.
      • If you're using an iOpener it may take several cycles of reheating and applying it to soften the adhesive enough. Every time, let the iOpener sit on the display for at least a minute before reheating to allow the adhesive to soften.
      Ask FixBot
    2. Microsoft Surface Pro Battery Replacement, Lift display and cut adhesive: step 2, image 1 of 3 Microsoft Surface Pro Battery Replacement, Lift display and cut adhesive: step 2, image 2 of 3 Microsoft Surface Pro Battery Replacement, Lift display and cut adhesive: step 2, image 3 of 3
      • Apply a suction cup as close as possible to the edge of the display.
      • Use the suction cup to lift the edge of the display enough to insert an opening pick under the edge.
      • Slide the opening pick all the way around the edges of the display to cut through the adhesive on the bezel.
      • Do not insert the opening pick past the bezel of the display—you may permanently damage the display.
      • The bezel is much thinner on the bottom of the display, which is the side with the Windows logo. To avoid damage, don't poke too deep with the opening pick on the bottom edge.
      • Ribbon cables and a circuit board are approx. 0.6 cm from the edge of the glass.
      • Be very careful and move slowly during this step. The display is fragile and will crack if too much force is applied against it. If your tools seem stuck, apply more heat to further soften the adhesive.
      Ask FixBot
    3. Microsoft Surface Pro Battery Replacement, Disconnect/peel off ribbon cables: step 3, image 1 of 3 Microsoft Surface Pro Battery Replacement, Disconnect/peel off ribbon cables: step 3, image 2 of 3 Microsoft Surface Pro Battery Replacement, Disconnect/peel off ribbon cables: step 3, image 3 of 3
      • Starting from the top edge, lift the display slightly.
      • If you feel any resistance, use heat and an opening pick to slice through any remaining adhesive.
      • Before completely removing the display:
      • Disconnect the three display cables.
      • Gently peel from the frame 2 orange ribbon cables that are glued to it, as those should stay with the display. (e.g. use a thin plastic card to separate them)
      Ask FixBot
    4. Microsoft Surface Pro Battery Replacement, Removal: step 4, image 1 of 1
      • Remove the display.
      Ask FixBot
    1. Microsoft Surface Pro Battery Replacement, Battery: step 5, image 1 of 2 Microsoft Surface Pro Battery Replacement, Battery: step 5, image 2 of 2
      • Using a T3 Torx screwdriver, remove a total of 23 screws from the screen bezel of the Surface Pro.
      Ask FixBot
    2. Microsoft Surface Pro Battery Replacement: step 6, image 1 of 1
      • Lift the screen bezel from the Surface Pro.
      Ask FixBot
    3. Microsoft Surface Pro Battery Replacement: step 7, image 1 of 2 Microsoft Surface Pro Battery Replacement: step 7, image 2 of 2
      • Remove the 6 T5 screws from the panels on each side of the frame.
      • Remove 23 T2 screws from the panels.
      Ask FixBot
    4. Microsoft Surface Pro Battery Replacement: step 8, image 1 of 1
      • Lift both metal panels from the frame.
      Ask FixBot
    5. Microsoft Surface Pro Battery Replacement: step 9, image 1 of 2 Microsoft Surface Pro Battery Replacement: step 9, image 2 of 2
      Tool used on this step:
      Buy
      • Using tweezers, gently pull the eight orange ribbon cables from their sockets.
      Ask FixBot
    6. Microsoft Surface Pro Battery Replacement: step 10, image 1 of 2 Microsoft Surface Pro Battery Replacement: step 10, image 2 of 2
      • Unscrew the 17 T5 torx screws on the mother board with the T5 torx screw driver
      Ask FixBot
    7. Microsoft Surface Pro Battery Replacement: step 11, image 1 of 1
      • Once all screws are removed, gently lift up the logic board with your hands to pull it out.
      Ask FixBot
    8. Microsoft Surface Pro Battery Replacement: step 12, image 1 of 2 Microsoft Surface Pro Battery Replacement: step 12, image 2 of 2
      • Use your hands to pry off the entire battery pack with enough force to overcome the glue keeping the batteries in place.
      Ask FixBot
41 other people completed this guide.
Author
with
Jonathan Choi
1,096 Reputation
4 Guides authored
Cal Poly, Team 8-20, Regan Fall 2013 Member of Cal Poly, Team 8-20, Regan Fall 2013
CPSU-REGAN-F13S8G20
4 Members
60 Guides authored
24 Guide Comments
Thank you for that awesome guide!
Do you know where can i buy a battery for surface pro 2??
Thanks
John john - Reply Share
I am also trying to find out where to acquire the Surface Pro batteries...???
Tristan Irons - Reply Share
im also looking for a surface pro replacement battery.
Lekan Adesanya - Reply Share
I just bought one for $70 at a site called newpower99.com... should be here in 2 days. I have no idea if it will work, but it says it comes with a toolkit to replace it. I hope it works.
Matt - Reply Share
Did you have success installing the Newegg battery?
asmac - Reply Share
Past 24 Hours: 23
Past 7 Days: 199
Past 30 Days: 943
All Time: 274,218
