Microsoft Surface Pro 8 SSD Replacement
    1. Microsoft Surface Pro 8 SSD Replacement, Before you begin: step 1, image 1 of 1
      • Before starting your repair, unplug all cables and fully shut down your Surface Pro.
      Ask FixBot
    1. Microsoft Surface Pro 8 SSD Replacement, Open the kickstand: step 2, image 1 of 2 Microsoft Surface Pro 8 SSD Replacement, Open the kickstand: step 2, image 2 of 2
      • Open the kickstand to about 90 degrees.
      Ask FixBot
    1. Microsoft Surface Pro 8 SSD Replacement, Remove the SSD door: step 3, image 1 of 3 Microsoft Surface Pro 8 SSD Replacement, Remove the SSD door: step 3, image 2 of 3 Microsoft Surface Pro 8 SSD Replacement, Remove the SSD door: step 3, image 3 of 3
      • Firmly press a SIM eject tool into the small hole in the corner of the SSD door until it pops up.
      • Alternatively, you can also use a small, straightened paper clip.
      • Remove the SSD door.
      Ask FixBot
    1. Microsoft Surface Pro 8 SSD Replacement, Remove the SSD screw: step 4, image 1 of 2 Microsoft Surface Pro 8 SSD Replacement, Remove the SSD screw: step 4, image 2 of 2
      • Removing the SSD also functions as a battery disconnect and should be done before all major repairs.
      • Use a Torx Plus 3IP screwdriver to remove the 2.3 mm‑long screw securing the SSD.
      Ask FixBot
    2. Microsoft Surface Pro 8 SSD Replacement, Remove SSD: step 5, image 1 of 2 Microsoft Surface Pro 8 SSD Replacement, Remove SSD: step 5, image 2 of 2
      • Don't pull up at a sharp angle, or you may damage the SSD and its socket.
      • Use your fingers to pull the SSD out of its socket at a shallow angle.
      • If you're having trouble gripping the SSD, use a spudger or your fingernail to lift it slightly.
      Ask FixBot
To reassemble your device, follow these instructions in reverse order. Once your laptop is reassembled, follow Microsoft's post SSD replacement guide.
9 other people completed this guide.
Spencer Day
206,456 Reputation
1,266 Guides authored
6 Guide Comments
The screw and required driver are NOT T4 but Torx Plus 3IP (Torx 3 will do the job) according to the MS Service Manual (856727 Microsoft Surface Surface Pro 8 Service Guide - linked at the product page here at ifixit.
Waldbaer - Reply Share
We've updated the guide, which now includes the correct driver type. Thank you for the comment!
Spencer Day - Reply Share
If your Screw Strips, like the one of my GF did, you will need a M 1.2 x 2 Screw and a washer to secure the SSD again. I got mine here: https://online-schrauben.de/shop/
They aren't cheap but the fit, aren't too long and work properly, unlike the ones you get from Amazon.
The dimensions I used are:
DIN 84 ST M 1,2 x 2 (Screw)
ISO 7089 A2 200HV 1,6 (Washer)
Have a good one guys.
Heero Yuy - Reply Share
you just saved my butt. Thank you.
Alexander Weinhart - Reply Share
dude, thank you for checking this for me. <3
Karl Schulz - Reply Share
Past 24 Hours: 21
Past 7 Days: 115
Past 30 Days: 518
All Time: 45,206
