Microsoft Surface Pro 8 Kickstand Replacement
    1. Microsoft Surface Pro 8 Kickstand Replacement, Before you begin: step 1, image 1 of 1
      • Before starting your repair, unplug all cables and fully shut down your Surface Pro.
      Ask FixBot
    1. Microsoft Surface Pro 8 Kickstand Replacement, Open the kickstand: step 2, image 1 of 2 Microsoft Surface Pro 8 Kickstand Replacement, Open the kickstand: step 2, image 2 of 2
      • Open the kickstand to about 90 degrees.
      Ask FixBot
    1. Microsoft Surface Pro 8 Kickstand Replacement, Remove the hinge screws: step 3, image 1 of 3 Microsoft Surface Pro 8 Kickstand Replacement, Remove the hinge screws: step 3, image 2 of 3 Microsoft Surface Pro 8 Kickstand Replacement, Remove the hinge screws: step 3, image 3 of 3
      • While holding the kickstand behind the hinge with your finger, use a Torx Plus 3IP screwdriver to remove the 2.4 mm‑long screw from each hinge (two total).
      Ask FixBot
    2. Microsoft Surface Pro 8 Kickstand Replacement, Lower the kickstand: step 4, image 1 of 2 Microsoft Surface Pro 8 Kickstand Replacement, Lower the kickstand: step 4, image 2 of 2
      • Firmly grip the hinges and kickstand between your thumb and index fingers.
      • Lower the kickstand down to about 45 degrees.
      • This may take a bit of force. Be careful not to pinch your thumbs.
      Ask FixBot
    3. Microsoft Surface Pro 8 Kickstand Replacement, Unlatch the hinges: step 5, image 1 of 3 Microsoft Surface Pro 8 Kickstand Replacement, Unlatch the hinges: step 5, image 2 of 3 Microsoft Surface Pro 8 Kickstand Replacement, Unlatch the hinges: step 5, image 3 of 3
      • The hinges slot into recesses on the kickstand. You need to slide the kickstand out of the hinges before you can fully remove it.
      • Firmly secure the device to your work surface with one hand.
      • With your free hand, pull the kickstand out slightly and rotate it up so both hinges slide out.
      • During reassembly, make sure both hinges slide fully into their recesses on the kickstand.
      Ask FixBot
    4. Microsoft Surface Pro 8 Kickstand Replacement, Remove the kickstand: step 6, image 1 of 2 Microsoft Surface Pro 8 Kickstand Replacement, Remove the kickstand: step 6, image 2 of 2
      • Pull the kickstand out until both foam tabs slide out.
      • If you're having trouble, make sure both hinges are fully out of their recesses on the kickstand.
      Ask FixBot
Spencer Day
206,459 Reputation
1,266 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 28
Past 30 Days: 130
All Time: 476
