Up to 20% off select tools
Microsoft Surface Pro 6 Screen Replacement
Views: 33K
View statistics:
Past 24 Hours:
11
Past 7 Days:
66
Past 30 Days:
299
All Time:
33,271
Comments: 16
7 comments on steps, 9 guide comments.
Go to guide comments
Completed: 11
11 people have marked this guide "completed." Will you be next?
Favorites: 5
5 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 30 minutes - 1 hour
Difficulty: Difficult
Featured Guide
This guide has been found to be exceptionally cool by the iFixit staff.
Fix Kit
This kit contains all the parts and tools needed to complete this guide.
Parts
Tools
Introduction
Go to step 1 ↓
Use this guide to replace a cracked or broken screen on a Microsoft Surface Pro 6.
There is a significant chance that you may break the unreinforced and fragile display panel during this procedure. Be sure to apply plenty of heat and be extremely careful during the prying stage.
    1. Microsoft Surface Pro 6 Screen Replacement, Heat the screen: step 1, image 1 of 1
      • Completely power off the Surface before you begin disassembly.
      • If the screen's glass is cracked, keep further breakage contained and prevent bodily harm during your repair by taping over the glass. Lay overlapping strips of clear packing tape over the display until all the glass is covered. Wear safety glasses to protect your eyes.
      • Heat an iOpener and apply it to the right edge of the Surface's screen for two minutes.
      • You may need to reheat and reapply the iOpener several times to get the Surface warm enough. Follow the iOpener instructions to avoid overheating.
      • A hair dryer, heat gun, or hot plate may also be used for more heat, but be careful not to overheat the Surface—the screen and internal battery are susceptible to heat damage.
      Ask FixBot
    2. Microsoft Surface Pro 6 Screen Replacement, Take note of the adhesive layout: step 2, image 1 of 2 Microsoft Surface Pro 6 Screen Replacement, Take note of the adhesive layout: step 2, image 2 of 2
      • Take note of the screen adhesive layout before continuing:
      • These areas only contain adhesive and are safe to cut.
      • The display board and flex cables sit here close to the edge. Cut very carefully and do not insert the pick as deep under the display.
      • Fragile antenna cables lie under this part of the screen. Carefully follow the procedure to avoid damaging them. The adhesive is also the thickest here.
      Ask FixBot
    3. Microsoft Surface Pro 6 Screen Replacement, Insert an opening pick into the speaker opening: step 3, image 1 of 2 Microsoft Surface Pro 6 Screen Replacement, Insert an opening pick into the speaker opening: step 3, image 2 of 2
      • Insert an opening pick into the speaker opening on the screen and slide the pick under the glass. Do not press the pick into the speaker grille, as the grille is easily torn.
      • Don't insert the opening pick any deeper than the black bezel on the side of the screen. Inserting the pick too far may damage the LCD.
      Ask FixBot
    4. Microsoft Surface Pro 6 Screen Replacement, Slide an opening pick under the screen: step 4, image 1 of 2 Microsoft Surface Pro 6 Screen Replacement, Slide an opening pick under the screen: step 4, image 2 of 2
      • Rotate the pick toward the bottom of the Surface to slide it underneath the lower edge of the speaker cutout.
      Ask FixBot
    5. Microsoft Surface Pro 6 Screen Replacement, Cut through the screen adhesive: step 5, image 1 of 2 Microsoft Surface Pro 6 Screen Replacement, Cut through the screen adhesive: step 5, image 2 of 2
      • Slide the pick down the right edge of the Surface to slice through the adhesive under the screen.
      • Throughout the rest of the procedure, if you encounter significant resistance while sliding the pick, stop and reheat the section you're working on. Applying too much pressure with the pick can crack the glass.
      • Leave this opening pick in the right edge to prevent the adhesive from resealing.
      Ask FixBot
    6. Microsoft Surface Pro 6 Screen Replacement: step 6, image 1 of 1
      • Reheat the iOpener and apply it to the bottom edge of the Surface's screen for two minutes.
      Ask FixBot
    7. Microsoft Surface Pro 6 Screen Replacement: step 7, image 1 of 3 Microsoft Surface Pro 6 Screen Replacement: step 7, image 2 of 3 Microsoft Surface Pro 6 Screen Replacement: step 7, image 3 of 3
      • Insert a new opening pick into the bottom right corner and slide it around the corner toward the bottom edge.
      • Slide the pick along the bottom edge of the Surface to cut through the screen adhesive.
      • Leave this pick in the bottom edge to prevent the adhesive from resealing.
      Ask FixBot
    8. Microsoft Surface Pro 6 Screen Replacement: step 8, image 1 of 1
      • Reheat the iOpener and apply it to the left edge of the Surface's screen for two minutes.
      Ask FixBot
    9. Microsoft Surface Pro 6 Screen Replacement: step 9, image 1 of 3 Microsoft Surface Pro 6 Screen Replacement: step 9, image 2 of 3 Microsoft Surface Pro 6 Screen Replacement: step 9, image 3 of 3
      • Insert a new opening pick into the bottom left corner and slide it around the corner toward the left edge.
      • Take care cutting under the lower 2.5 inches (65 mm) of the left edge. Do not insert the opening pick more than 1/8 inches (3 mm) here. The display cables sit near this part of the bezel and are easily damaged. Once past the display cable area, do not insert the pick past the bezel.
      • Slide the pick along the left edge of the Surface to cut through the screen adhesive.
      • Leave this pick in the left edge to prevent the adhesive from resealing.
      Ask FixBot
    10. Microsoft Surface Pro 6 Screen Replacement: step 10, image 1 of 1
      • Reheat the iOpener and apply it to the top edge of the Surface's screen for two minutes.
      • The adhesive is thickest along this edge, and you may need to reheat and reapply the iOpener several times to get the Surface warm enough. Follow the iOpener instructions to avoid overheating.
      Ask FixBot
    11. Microsoft Surface Pro 6 Screen Replacement: step 11, image 1 of 3 Microsoft Surface Pro 6 Screen Replacement: step 11, image 2 of 3 Microsoft Surface Pro 6 Screen Replacement: step 11, image 3 of 3
      • Round the left corner with the opening pick and slide it along the top edge of the Surface. Stop when the pick is 2.75 inches (70 mm) away from the left edge.
      • The next 6 inches (15 cm) of the top edge of the case is covered by the left and right antennas, which sit between the case and the screen bezel. Follow the next steps carefully to avoid damaging the antennas.
      Ask FixBot
    12. Microsoft Surface Pro 6 Screen Replacement: step 12, image 1 of 3 Microsoft Surface Pro 6 Screen Replacement: step 12, image 2 of 3 Microsoft Surface Pro 6 Screen Replacement: step 12, image 3 of 3
      • Insert the point of a pick under the display where you just stopped cutting. Do not insert the pick deeper than the edge of the bezel.
      • Carefully roll the pick to the right, pressing the long edge of the pick into the screen adhesive underneath the bezel, cutting the adhesive as you go. Do not slide the pick along the edge of the Surface.
      • Keep the pick parallel to the screen throughout the whole procedure so that it doesn't catch on the antennas. Do not press the pick against the case.
      • Repeat this motion of inserting the point of the pick where you just cut, and rolling to the right all along the top edge of the Surface, until the pick is 2.5 inches (64 mm) from the right edge of the Surface.
      Ask FixBot
    13. Microsoft Surface Pro 6 Screen Replacement: step 13, image 1 of 3 Microsoft Surface Pro 6 Screen Replacement: step 13, image 2 of 3 Microsoft Surface Pro 6 Screen Replacement: step 13, image 3 of 3
      • Once you cut the adhesive over the antennas (8.5 inches, or 22 cm, away from the left edge), slide the pick the rest of the way along the top edge of the surface and round the top right corner to slice through any remaining adhesive.
      Ask FixBot
    14. Microsoft Surface Pro 6 Screen Replacement, Open the Surface: step 14, image 1 of 3 Microsoft Surface Pro 6 Screen Replacement, Open the Surface: step 14, image 2 of 3 Microsoft Surface Pro 6 Screen Replacement, Open the Surface: step 14, image 3 of 3
      • Very slowly lift the screen assembly away from the Surface case. If you encounter any resistance, stop and check that all the adhesive is separated.
      • Do not remove the screen yet. It is still connected to the motherboard by two cables.
      • Use an opening pick to cut through any remaining adhesive.
      • The flash lens may fall out of the Surface case. Keep track of the lens and return it to its cutout in the case during reassembly.
      Ask FixBot
    15. Microsoft Surface Pro 6 Screen Replacement: step 15, image 1 of 3 Microsoft Surface Pro 6 Screen Replacement: step 15, image 2 of 3 Microsoft Surface Pro 6 Screen Replacement: step 15, image 3 of 3
      • Lift the top of the screen assembly away from the case while sliding the bottom of the screen closer to the motherboard display connectors.
      • Gently lay the screen down on the case with the connectors facing up. Take care to avoid creasing the display cables.
      Ask FixBot
    16. Microsoft Surface Pro 6 Screen Replacement, Disconnect the screen: step 16, image 1 of 2 Microsoft Surface Pro 6 Screen Replacement, Disconnect the screen: step 16, image 2 of 2
      • Use an opening pick to pry up one edge of the EMI shield covering the display board.
      • Repeat this procedure at different points around the shield until it is free.
      • Try not to deform the shield too much—you will need to reinstall it during reassembly.
      Ask FixBot
    17. Microsoft Surface Pro 6 Screen Replacement: step 17, image 1 of 1
      • Lift the EMI shield away from the display board and remove it.
      Ask FixBot
    18. Microsoft Surface Pro 6 Screen Replacement: step 18, image 1 of 2 Microsoft Surface Pro 6 Screen Replacement: step 18, image 2 of 2
      • Use the flat end of a spudger to pry the display interconnect cable straight up and out of its socket on the board.
      Ask FixBot
    19. Microsoft Surface Pro 6 Screen Replacement: step 19, image 1 of 2 Microsoft Surface Pro 6 Screen Replacement: step 19, image 2 of 2
      Tool used on this step:
      Buy
      • Insert one point of a pair of pointed tweezers into a gap in the edge of the EMI shield covering the digitizer connector.
      • Use the tweezers to pry the EMI shield away from the display as much as you can without bending it.
      • Repeat this procedure at different points around the shield until it is free. Remove the shield.
      Ask FixBot
    20. Microsoft Surface Pro 6 Screen Replacement: step 20, image 1 of 1
      • Pull the rest of the shield off of the digitizer connector and remove it.
      Ask FixBot
    21. Microsoft Surface Pro 6 Screen Replacement: step 21, image 1 of 2 Microsoft Surface Pro 6 Screen Replacement: step 21, image 2 of 2
      • Use the tip of a spudger to pry the digitizer connector straight up and out of its socket on the screen.
      Ask FixBot
    22. Microsoft Surface Pro 6 Screen Replacement: step 22, image 1 of 1
      • Remove the screen assembly from the Surface.
      • During reassembly, pause here and follow this guide to replace the screen adhesive.
      Ask FixBot
    1. Microsoft Surface Pro 6 Screen Replacement, Disconnect the display board: step 23, image 1 of 3 Microsoft Surface Pro 6 Screen Replacement, Disconnect the display board: step 23, image 2 of 3 Microsoft Surface Pro 6 Screen Replacement, Disconnect the display board: step 23, image 3 of 3
      • Use a spudger to flip up the small locking flaps on the display cable ZIF connectors.
      Ask FixBot
    2. Microsoft Surface Pro 6 Screen Replacement: step 24, image 1 of 3 Microsoft Surface Pro 6 Screen Replacement: step 24, image 2 of 3 Microsoft Surface Pro 6 Screen Replacement: step 24, image 3 of 3
      Buy
      • Use tweezers to slide the display cables straight out of their sockets on the display board.
      Ask FixBot
    3. Microsoft Surface Pro 6 Screen Replacement, Remove the display board: step 25, image 1 of 3 Microsoft Surface Pro 6 Screen Replacement, Remove the display board: step 25, image 2 of 3 Microsoft Surface Pro 6 Screen Replacement, Remove the display board: step 25, image 3 of 3
      • Slide an opening pick under the display board to separate the adhesive holding it onto the back of the screen.
      • If the adhesive is stubborn, it may help to heat the display board using an iOpener, hair dryer, or heat gun. Take care not to overheat the display.
      Ask FixBot
    4. Microsoft Surface Pro 6 Screen Replacement: step 26, image 1 of 1
      Tesa 61395 Tape
      $8.95
      Buy
      • Remove the display board.
      • During reassembly, use a strong double-sided tape or a precut adhesive card to secure the display board. Clean off old adhesive before applying new adhesive.
      • To ensure correct positioning, plug in both display connectors before adhering the board to the display.
      Ask FixBot
    5. Microsoft Surface Pro 6 Screen Replacement: step 27, image 1 of 1
      • Only the screen remains.
      Ask FixBot
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers community for troubleshooting help.
11 other people completed this guide.
Author
with
Adam O'Camb
226,699 Reputation
415 Guides authored
9 Guide Comments
Surprised there’s no comments on this. Thanks Adam for the walkthrough. I used your guide to fix a bent frame and I appreciated the instruction as it proved very useful.
Kyle Wood - Reply Share
Thank you Adam for the Tuto it’s helpful and thank to the community in here.
let’s fix it :)
PS : why can’t we find the screens on here ???
Sly - Reply Share
thank you very much Adam
Bahir Raad - Reply Share
Ya I can say difficult. I miss the old laptops. Thanks for helping it went smoothly.
Stephen Michalski - Reply Share
If your surface pro is working except for the cracked screen, I suggest backing ervything to another device.
While the instructions are good, I had a hard time removing the display. Suggest wearing eye protection. Glass everywhere.
Tough to clean up the remaning adhesive. I used droplets of goo gone.
I had difficulty reinserting the display ribbons and unfortuantely my surface pro is now toast. :(
No fault of the parts or instructions. Just wasn't meant to be.
I can see why no places want to serive these things.
Steven Schlossman - Reply Share
Past 24 Hours: 11
Past 7 Days: 66
Past 30 Days: 299
All Time: 33,271
