Microsoft Surface Pro 5 Power, Volume Button, and Left Speaker Assembly Replacement
Archived Guide
This guide is retained solely for historical purposes. Use the updated version of the guide to perform your repair.
    1. Microsoft Surface Pro 5 Power, Volume Button, and Left Speaker Assembly Replacement, Disconnect the display board: step 1, image 1 of 3 Microsoft Surface Pro 5 Power, Volume Button, and Left Speaker Assembly Replacement, Disconnect the display board: step 1, image 2 of 3 Microsoft Surface Pro 5 Power, Volume Button, and Left Speaker Assembly Replacement, Disconnect the display board: step 1, image 3 of 3
      • Use a spudger to flip up the small locking flaps on the display cable ZIF connectors.
      Ask FixBot
    2. Microsoft Surface Pro 5 Power, Volume Button, and Left Speaker Assembly Replacement: step 2, image 1 of 3 Microsoft Surface Pro 5 Power, Volume Button, and Left Speaker Assembly Replacement: step 2, image 2 of 3 Microsoft Surface Pro 5 Power, Volume Button, and Left Speaker Assembly Replacement: step 2, image 3 of 3
      Tool used on this step:
      Buy
      • Use tweezers to slide the display cables straight out of their sockets on the display board.
      Ask FixBot
    3. Microsoft Surface Pro 5 Power, Volume Button, and Left Speaker Assembly Replacement, Remove the display board: step 3, image 1 of 3 Microsoft Surface Pro 5 Power, Volume Button, and Left Speaker Assembly Replacement, Remove the display board: step 3, image 2 of 3 Microsoft Surface Pro 5 Power, Volume Button, and Left Speaker Assembly Replacement, Remove the display board: step 3, image 3 of 3
      • Slide an opening pick under the display board to separate the adhesive holding it onto the back of the screen.
      Ask FixBot
    4. Microsoft Surface Pro 5 Power, Volume Button, and Left Speaker Assembly Replacement: step 4, image 1 of 1
      Tesa 61395 Tape
      $8.95
      Buy
      • Remove the display board.
      • During reassembly, use a strong double-sided tape or a precut adhesive card to secure the display board. Clean off the old adhesive before applying new adhesive.
      • To ensure correct positioning, plug in both display connectors before adhering the board to the display.
      Ask FixBot
    5. Microsoft Surface Pro 5 Power, Volume Button, and Left Speaker Assembly Replacement: step 5, image 1 of 1
      • Only the screen remains.
      Ask FixBot
    1. Microsoft Surface Pro 5 Power, Volume Button, and Left Speaker Assembly Replacement, Remove the heat sink shield: step 6, image 1 of 2 Microsoft Surface Pro 5 Power, Volume Button, and Left Speaker Assembly Replacement, Remove the heat sink shield: step 6, image 2 of 2
      Buy
      • Insert one point of a pair of pointed tweezers into a gap in the corner of the EMI shield covering the heat sink.
      • Use the tweezers to pry the EMI shield away from the motherboard as much as you can without bending it. Do not remove it yet.
      • Try not to deform the shield too much—you will need to reinstall it during reassembly.
      • Take care not to puncture the battery with the tweezers while working on this shield.
      Ask FixBot
    2. Microsoft Surface Pro 5 Power, Volume Button, and Left Speaker Assembly Replacement: step 7, image 1 of 3 Microsoft Surface Pro 5 Power, Volume Button, and Left Speaker Assembly Replacement: step 7, image 2 of 3 Microsoft Surface Pro 5 Power, Volume Button, and Left Speaker Assembly Replacement: step 7, image 3 of 3
      • Repeat the last step for each corner of the EMI shield covering the heat sink.
      Ask FixBot
    3. Microsoft Surface Pro 5 Power, Volume Button, and Left Speaker Assembly Replacement: step 8, image 1 of 1
      • Remove the heat sink shield.
      Ask FixBot
    4. Microsoft Surface Pro 5 Power, Volume Button, and Left Speaker Assembly Replacement, Remove the heat sink: step 9, image 1 of 2 Microsoft Surface Pro 5 Power, Volume Button, and Left Speaker Assembly Replacement, Remove the heat sink: step 9, image 2 of 2
      • Remove the nine Torx screws securing the heat sink:
      • Five 2.6 mm-long T3 screws
      • Four 3.3 mm-long T5 screws
      • During reassembly, tighten the heat sink screws in the following criss-cross pattern, one turn at a time, until they're tight:
      • Screw 1
      • Screw 2
      • Screw 3
      • Screw 4
      Ask FixBot
    5. Microsoft Surface Pro 5 Power, Volume Button, and Left Speaker Assembly Replacement: step 10, image 1 of 3 Microsoft Surface Pro 5 Power, Volume Button, and Left Speaker Assembly Replacement: step 10, image 2 of 3 Microsoft Surface Pro 5 Power, Volume Button, and Left Speaker Assembly Replacement: step 10, image 3 of 3
      Ask FixBot
    1. Microsoft Surface Pro 5 Power, Volume Button, and Left Speaker Assembly Replacement, Camera Tie Bar: step 11, image 1 of 1
      • Remove the Torx T5 x 6mm screw connecting the black tie bar to the power button/volume control/speaker assembly.
      Ask FixBot
    2. Microsoft Surface Pro 5 Power, Volume Button, and Left Speaker Assembly Replacement: step 12, image 1 of 1
      • Remove the remaining three Torx T5 x 4.5mm screws holding down the camera tie bar.
      Ask FixBot
    3. Microsoft Surface Pro 5 Power, Volume Button, and Left Speaker Assembly Replacement: step 13, image 1 of 1
      Buy
      • Disconnect the small ribbon cable connecting the camera tie bar to the motherboard by pulling up with tweezers.
      Ask FixBot
    4. Microsoft Surface Pro 5 Power, Volume Button, and Left Speaker Assembly Replacement: step 14, image 1 of 1
      • Lift the camera tie bar off of the device.
      Ask FixBot
    1. Microsoft Surface Pro 5 Power, Volume Button, and Left Speaker Assembly Replacement, Power Button, Volume Buttons, and Left Speaker Assembly: step 15, image 1 of 1
      • Use a Torx T5 to remove the two 4.5mm silver screws on the power button/volume control/speaker assembly.
      Ask FixBot
    2. Microsoft Surface Pro 5 Power, Volume Button, and Left Speaker Assembly Replacement: step 16, image 1 of 2 Microsoft Surface Pro 5 Power, Volume Button, and Left Speaker Assembly Replacement: step 16, image 2 of 2
      Buy
      • Disconnect the small ribbon attaching the assembly to the motherboard by lifting up with tweezers.
      • Disconnect the black and red cable connector by lifting up with tweezers.
      Ask FixBot
    3. Microsoft Surface Pro 5 Power, Volume Button, and Left Speaker Assembly Replacement: step 17, image 1 of 1
      • Pull the assembly to the left with hands and lift up to remove.
      Ask FixBot
Kaden Foster
897 Reputation
3 Guides authored
Cal Poly, Team S15-G3, Livingston Fall 2017 Member of Cal Poly, Team S15-G3, Livingston Fall 2017
CPSU-LIVINGSTON-F17S15G3
3 Members
85 Guides authored
1 Guide Comment
Hi,
Where can I purchase the power button assembly in the UK?
junaidpatel - Reply Share
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 53
All Time: 3,294
