Microsoft Surface Pro 5 Front and Rear Camera Replacement
Views: 2.1K
View statistics:
Past 24 Hours:
Past 7 Days:
13
Past 30 Days:
41
All Time:
2,103
Comments: 11
10 comments on steps, 1 guide comment.
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 2 - 3 hours
Difficulty: Difficult
Archived Guide This guide is retained solely for historical purposes. Use the updated version of the guide to perform your repair.
Introduction
Go to step 1 ↓
This guide will go over how to replace the cameras on the Microsoft Surface Pro 5, also known as the Microsoft Surface Pro (2017). The Microsoft Surface Pro 5 has two cameras: one front facing and one rear facing. Both are located underneath the black tie bar. The iOpener is used in this guide, but a hair dryer or heat gun could also be used. See instructions for the iOpener here.
Parts
Tools
    1. Microsoft Surface Pro 5 Front and Rear Camera Replacement, Disconnect the display board: step 1, image 1 of 3 Microsoft Surface Pro 5 Front and Rear Camera Replacement, Disconnect the display board: step 1, image 2 of 3 Microsoft Surface Pro 5 Front and Rear Camera Replacement, Disconnect the display board: step 1, image 3 of 3
      • Use a spudger to flip up the small locking flaps on the display cable ZIF connectors.
      Ask FixBot
    2. Microsoft Surface Pro 5 Front and Rear Camera Replacement: step 2, image 1 of 3 Microsoft Surface Pro 5 Front and Rear Camera Replacement: step 2, image 2 of 3 Microsoft Surface Pro 5 Front and Rear Camera Replacement: step 2, image 3 of 3
      Tool used on this step:
      Buy
      • Use tweezers to slide the display cables straight out of their sockets on the display board.
      Ask FixBot
    3. Microsoft Surface Pro 5 Front and Rear Camera Replacement, Remove the display board: step 3, image 1 of 3 Microsoft Surface Pro 5 Front and Rear Camera Replacement, Remove the display board: step 3, image 2 of 3 Microsoft Surface Pro 5 Front and Rear Camera Replacement, Remove the display board: step 3, image 3 of 3
      • Slide an opening pick under the display board to separate the adhesive holding it onto the back of the screen.
      Ask FixBot
    4. Microsoft Surface Pro 5 Front and Rear Camera Replacement: step 4, image 1 of 1
      Tesa 61395 Tape
      $8.95
      Buy
      • Remove the display board.
      • During reassembly, use a strong double-sided tape or a precut adhesive card to secure the display board. Clean off the old adhesive before applying new adhesive.
      • To ensure correct positioning, plug in both display connectors before adhering the board to the display.
      Ask FixBot
    5. Microsoft Surface Pro 5 Front and Rear Camera Replacement: step 5, image 1 of 1
      • Only the screen remains.
      Ask FixBot
    1. Microsoft Surface Pro 5 Front and Rear Camera Replacement, Remove the heat sink shield: step 6, image 1 of 2 Microsoft Surface Pro 5 Front and Rear Camera Replacement, Remove the heat sink shield: step 6, image 2 of 2
      Buy
      • Insert one point of a pair of pointed tweezers into a gap in the corner of the EMI shield covering the heat sink.
      • Use the tweezers to pry the EMI shield away from the motherboard as much as you can without bending it. Do not remove it yet.
      • Try not to deform the shield too much—you will need to reinstall it during reassembly.
      • Take care not to puncture the battery with the tweezers while working on this shield.
      Ask FixBot
    2. Microsoft Surface Pro 5 Front and Rear Camera Replacement: step 7, image 1 of 3 Microsoft Surface Pro 5 Front and Rear Camera Replacement: step 7, image 2 of 3 Microsoft Surface Pro 5 Front and Rear Camera Replacement: step 7, image 3 of 3
      • Repeat the last step for each corner of the EMI shield covering the heat sink.
      Ask FixBot
    3. Microsoft Surface Pro 5 Front and Rear Camera Replacement: step 8, image 1 of 1
      • Remove the heat sink shield.
      Ask FixBot
    4. Microsoft Surface Pro 5 Front and Rear Camera Replacement, Remove the heat sink: step 9, image 1 of 2 Microsoft Surface Pro 5 Front and Rear Camera Replacement, Remove the heat sink: step 9, image 2 of 2
      • Remove the nine Torx screws securing the heat sink:
      • Five 2.6 mm-long T3 screws
      • Four 3.3 mm-long T5 screws
      • During reassembly, tighten the heat sink screws in the following criss-cross pattern, one turn at a time, until they're tight:
      • Screw 1
      • Screw 2
      • Screw 3
      • Screw 4
      Ask FixBot
    5. Microsoft Surface Pro 5 Front and Rear Camera Replacement: step 10, image 1 of 3 Microsoft Surface Pro 5 Front and Rear Camera Replacement: step 10, image 2 of 3 Microsoft Surface Pro 5 Front and Rear Camera Replacement: step 10, image 3 of 3
      Ask FixBot
    1. Microsoft Surface Pro 5 Front and Rear Camera Replacement, Camera Tie Bar: step 11, image 1 of 1
      • Remove the Torx T5 x 6mm screw connecting the black tie bar to the power button/volume control/speaker assembly.
      Ask FixBot
    2. Microsoft Surface Pro 5 Front and Rear Camera Replacement: step 12, image 1 of 1
      • Remove the remaining three Torx T5 x 4.5mm screws holding down the camera tie bar.
      Ask FixBot
    3. Microsoft Surface Pro 5 Front and Rear Camera Replacement: step 13, image 1 of 1
      Buy
      • Disconnect the small ribbon cable connecting the camera tie bar to the motherboard by pulling up with tweezers.
      Ask FixBot
    4. Microsoft Surface Pro 5 Front and Rear Camera Replacement: step 14, image 1 of 1
      • Lift the camera tie bar off of the device.
      Ask FixBot
    1. Microsoft Surface Pro 5 Front and Rear Camera Replacement, Front and Rear Camera: step 15, image 1 of 1
      • Pry off the metal cover covering the front and rear camera ribbon cable motherboard connections using a nylon spudger.
      Ask FixBot
    2. Microsoft Surface Pro 5 Front and Rear Camera Replacement: step 16, image 1 of 1
      • Lift the front camera ribbon cable off the motherboard using the nylon spudger.
      Ask FixBot
    3. Microsoft Surface Pro 5 Front and Rear Camera Replacement: step 17, image 1 of 1
      • Remove the front camera.
      Ask FixBot
    4. Microsoft Surface Pro 5 Front and Rear Camera Replacement: step 18, image 1 of 1
      • Remove the two Torx T3 x 2.5mm screws holding down the rear camera.
      Ask FixBot
    5. Microsoft Surface Pro 5 Front and Rear Camera Replacement: step 19, image 1 of 1
      • Lift the rear camera ribbon cable off the motherboard using the nylon spudger.
      Ask FixBot
    6. Microsoft Surface Pro 5 Front and Rear Camera Replacement: step 20, image 1 of 1
      • Remove the rear camera.
      Ask FixBot
Paul Manzer
762 Reputation
3 Guides authored
Cal Poly, Team S15-G3, Livingston Fall 2017 Member of Cal Poly, Team S15-G3, Livingston Fall 2017
CPSU-LIVINGSTON-F17S15G3
3 Members
96 Guides authored
1 Guide Comment
In step 19, there is a loose, clear plastic piece next to the front camera. In my disassembly, that piece managed to get lost. Can anyone tell me what the name of that part is, and where I can get one?
Charley Ballmer - Reply Share
Past 24 Hours: 1
Past 7 Days: 13
Past 30 Days: 41
All Time: 2,103
