Microsoft Surface Pro 4 Kickstand Replacement
    1. Microsoft Surface Pro 4 Kickstand Replacement, Open the kickstand: step 1, image 1 of 3 Microsoft Surface Pro 4 Kickstand Replacement, Open the kickstand: step 1, image 2 of 3 Microsoft Surface Pro 4 Kickstand Replacement, Open the kickstand: step 1, image 3 of 3
      • Place your device screen-down on a clean work surface.
      • Place your device on top of a clean cloth, such as a microfiber towel, if you feel the need to protect against scratching.
      • Open the kickstand as wide as it is designed to go (about 135 degrees).
      Ask FixBot
    2. Microsoft Surface Pro 4 Kickstand Replacement, Unscrew the kickstand: step 2, image 1 of 2 Microsoft Surface Pro 4 Kickstand Replacement, Unscrew the kickstand: step 2, image 2 of 2
      • Use a T5 Torx screwdriver to remove the two 3.3 mm screws securing each hinge to the kickstand.
      • Support the kickstand from behind to prevent damage to the hinges while removing the screws.
      • Do not remove the kickstand yet.
      • The kickstand remains held in place by two flexible appendages between the hinges.
      Ask FixBot
    3. Microsoft Surface Pro 4 Kickstand Replacement, Close the kickstand: step 3, image 1 of 3 Microsoft Surface Pro 4 Kickstand Replacement, Close the kickstand: step 3, image 2 of 3 Microsoft Surface Pro 4 Kickstand Replacement, Close the kickstand: step 3, image 3 of 3
      • Press the kickstand from directly behind the hinges and close it fully.
      • Do not exert force on the kickstand anywhere except for behind the hinges.
      • This step does not apply during reassembly.
      Ask FixBot
    4. Microsoft Surface Pro 4 Kickstand Replacement, Remove the kickstand: step 4, image 1 of 3 Microsoft Surface Pro 4 Kickstand Replacement, Remove the kickstand: step 4, image 2 of 3 Microsoft Surface Pro 4 Kickstand Replacement, Remove the kickstand: step 4, image 3 of 3
      • Pull the kickstand straight out from the bottom of the device.
      • Begin reassembly now before proceeding to steps 5 and 6:
      • Install your new kickstand by inserting its two appendages into the back of the device.
      • Press your new kickstand towards the top of the device until it is fully inserted.
      • Open the kickstand 180 degrees to expose the hinges.
      Ask FixBot
    5. Microsoft Surface Pro 4 Kickstand Replacement, Reassembly tips: step 5, image 1 of 3 Microsoft Surface Pro 4 Kickstand Replacement, Reassembly tips: step 5, image 2 of 3 Microsoft Surface Pro 4 Kickstand Replacement, Reassembly tips: step 5, image 3 of 3
      • To open the hinge, insert your T5 Torx screwdriver into one of the screw holes and gently pry towards the top of your device until the hinge is exposed.
      • Make sure the complete step 4 and begin installing the kickstand first.
      Ask FixBot
    6. Microsoft Surface Pro 4 Kickstand Replacement: step 6, image 1 of 2 Microsoft Surface Pro 4 Kickstand Replacement: step 6, image 2 of 2
      • Use your fingers or the flat end of a spudger to pry the hinge up into its fully open position.
      Ask FixBot
6 other people completed this guide.
Sam Omiotek
100,961 Reputation
289 Guides authored
3 Guide Comments
Is there a way to fix or replace the hinge? The kickstand on my Surface Pro is fine but the left hinge broke so now it won’t hold it up
Joel Hanson - Reply Share
Joel - did you find a solution? My left hinge broke a week ago and I’m looking for a solution. Thanks!
Cora Willett - Reply Share
I’m sorry for the delayed reply. I didn’t check on the hinges when I was working on the guide and unfortunately I don’t have the device still. In my online research, I found that the hinges are replaceable but I wasn’t able to find replacement parts.
Sarah Westberg - Reply Share
Past 24 Hours: 2
Past 7 Days: 28
Past 30 Days: 99
All Time: 12,826
