Up to 20% off select tools
Microsoft Surface Pro 3 SSD Replacement
Views: 184K
View statistics:
Past 24 Hours:
16
Past 7 Days:
145
Past 30 Days:
615
All Time:
183,772
Comments: 36
17 comments on steps, 19 guide comments.
Go to guide comments
Completed: 50
50 people have marked this guide "completed." Will you be next?
Favorites: 8
8 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 1 - 2 hours
Difficulty: Very difficult
Parts
Tools
Introduction
Go to step 1 ↓
This guide will teach you how to safely remove your SSD from you Surface Pro 3. The guide starts by removing the screen and digitizer and then goes right into removing the SSD. This guide does not include details on how to clone the existing memory on your current SSD onto your new one.
    1. Microsoft Surface Pro 3 SSD Replacement, Display: step 1, image 1 of 2 Microsoft Surface Pro 3 SSD Replacement, Display: step 1, image 2 of 2
      • Before you begin, discharge the Surface Pro's battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally damaged during the repair.
      • The display is strongly glued to the frame of the device.
      • To remove the display, first soften the adhesive by applying heat. You can use a heat pad, heat gun, or iOpener. In a pinch, a hair dryer can also work.
      • Be careful when using a heat gun, as too much heat can permanently damage the display and/or battery.
      • Steadily and evenly heat the perimeter of the display until it's too hot to touch, and try to maintain that temperature for several minutes.
      Ask FixBot
    2. Microsoft Surface Pro 3 SSD Replacement: step 2, image 1 of 2 Microsoft Surface Pro 3 SSD Replacement: step 2, image 2 of 2
      • Use a suction cup or an iSclack to pull up on the glass and create a slight gap between the glass and the metal frame.
      • If your display is badly cracked, a suction cup may not adhere. It may help to first cover the display with a layer of packing tape. Alternatively, you can superglue your suction cup to the display.
      • Carefully insert an opening pick into the gap between the screen and the device to cut the adhesive.
      • Slide the pick around the sides and bottom of the display to cut the adhesive. Apply more heat as needed.
      • Work carefully—the glass is thin and will crack easily if you try to force it.
      • The wi-fi antennas are glued under the screen border along the top edge (on either side of the camera), and can be damaged easily. Use extra care when separating the top edge, and apply more heat if necessary.
      Ask FixBot
    3. Microsoft Surface Pro 3 SSD Replacement: step 3, image 1 of 3 Microsoft Surface Pro 3 SSD Replacement: step 3, image 2 of 3 Microsoft Surface Pro 3 SSD Replacement: step 3, image 3 of 3
      • Continue to heat sections of the screen with the heat gun.
      • As you make your way around the screen with the heat gun, use the plastic opening tool and the opening picks to pry the screen loose.
      • The screen is extremely thin and very easy to break. Be careful working with broken glass.
      Ask FixBot
    4. Microsoft Surface Pro 3 SSD Replacement: step 4, image 1 of 2 Microsoft Surface Pro 3 SSD Replacement: step 4, image 2 of 2
      • Lift the screen up carefully so that no wires are torn.
      Ask FixBot
    5. Microsoft Surface Pro 3 SSD Replacement: step 5, image 1 of 2 Microsoft Surface Pro 3 SSD Replacement: step 5, image 2 of 2
      • Remove the 3 mm T3 Torx screw securing the battery connector, and disconnect the battery connector.
      • Be careful not lose the small, rectangular bridge connector that lies underneath.
      Ask FixBot
    6. Microsoft Surface Pro 3 SSD Replacement: step 6, image 1 of 3 Microsoft Surface Pro 3 SSD Replacement: step 6, image 2 of 3 Microsoft Surface Pro 3 SSD Replacement: step 6, image 3 of 3
      • Remove the single 4 mm T3 Torx screw securing the display cable.
      • Lift the connector to disconnect the cable.
      Ask FixBot
    7. Microsoft Surface Pro 3 SSD Replacement: step 7, image 1 of 3 Microsoft Surface Pro 3 SSD Replacement: step 7, image 2 of 3 Microsoft Surface Pro 3 SSD Replacement: step 7, image 3 of 3
      • Grasp the orange cable connected to the silver connecter.
      • Carefully lift the orange cable up until the connecter pops off.
      • The screen will now be completely disconnected.
      • The replacement display may not include all the parts needed for installation. Save all the parts from the original display, and transfer them to the new display as needed.
      Ask FixBot
    1. Microsoft Surface Pro 3 SSD Replacement, SSD: step 8, image 1 of 3 Microsoft Surface Pro 3 SSD Replacement, SSD: step 8, image 2 of 3 Microsoft Surface Pro 3 SSD Replacement, SSD: step 8, image 3 of 3
      • Remove the two 4 mm T3 Torx screws securing the SSD.
      Ask FixBot
    2. Microsoft Surface Pro 3 SSD Replacement: step 9, image 1 of 2 Microsoft Surface Pro 3 SSD Replacement: step 9, image 2 of 2
      • Lift up and pull gently on the SSD to remove it from the black connector.
      Ask FixBot
50 other people completed this guide.
Author
with
Erik Snyder
5,460 Reputation
5 Guides authored
Cal Poly, Team 12-18, Maness Fall 2015 Member of Cal Poly, Team 12-18, Maness Fall 2015
CPSU-MANESS-F15S12G18
5 Members
60 Guides authored
19 Guide Comments
How do you replace the screen once the glue is melted?
bbhsascha - Reply Share
would assume you heat and put the screen back...
Assuming you havent shattered the screen to oblivion in the process...
nyalldavis - Reply Share
Is there a way to copy the files from the ssd card once removed?
Garry Lincoln - Reply Share
yes, you would need an adapter to connect the msata to regular sata and connect to another computer.
Dan Wooton - Reply Share
How's does the glass thickness compare to the Surface Pro 2? I've replaced a screen on a 2 without destroying it. Now I'm looking to replace an SSD on a 3. I'm wondering if I can expect the same type of removal.
jwelch414 - Reply Share
Past 24 Hours: 16
Past 7 Days: 145
Past 30 Days: 615
All Time: 183,772
