Microsoft Surface Pro 3 SSD Replacement Dodgy Style
Views: 8.3K
View statistics:
Past 24 Hours:
5
Past 7 Days:
41
Past 30 Days:
190
All Time:
8,324
Comments: 3
1 comment on steps, 2 guide comments.
Go to guide comments
Completed: 4
4 people have marked this guide "completed." Will you be next?
Favorites: 4
4 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 10 hours
Difficulty: Moderate
Scenic Route
This guide's procedure isn't the most efficient way to get the job done, but still may be useful in some circumstances.
Confusing Text
Some of this guide's text is confusing, duplicated, or off-topic. Clarify it by editing!
Markup Mishap
This guide needs better markups. Help out by correcting or making some markup annotations.
Community-Contributed Guide
Introduction
Go to step 1 ↓
This guide shows a second way to open a Surface Pro 3 and replace the drive without paying the money Microsoft wants and without risking destroying the display. This is not the original guide, but it's slightly better and safer than this guide.
    1. Microsoft Surface Pro 3 SSD Replacement Dodgy Style, Mark it: step 1, image 1 of 2 Microsoft Surface Pro 3 SSD Replacement Dodgy Style, Mark it: step 1, image 2 of 2
      • Print this off to scale it up to the right size of the surface and mark it up with a pencil.
      • When it is marked up it should look something like the second photo.
      • You need to reverse this image. This is shown with the screen off.
      Ask FixBot
      • You want to use a V bit on a CNC machine to cut it nicer and give it a chambered edge.
      • I used my CNC machine with no WD40 or water to cool it and it cut very nicely. Remember to vacuum the chunks as they come off because they can get caught and puncture the battery.
      • It's also a good idea to put some paper towel in between the clamps and the Surface. Also be sure to have the type cover on so you don't damage the screen.
      Ask FixBot
    2. Microsoft Surface Pro 3 SSD Replacement Dodgy Style, Unscrew it: step 3, image 1 of 2 Microsoft Surface Pro 3 SSD Replacement Dodgy Style, Unscrew it: step 3, image 2 of 2
      • The drive should just lift out, I used a Micro SD card to cover my serial number.
      Ask FixBot
    3. Microsoft Surface Pro 3 SSD Replacement Dodgy Style, Install it: step 4, image 1 of 1
      • Now this is where it gets interesting. you can either try to make the recovery USB from This or you can book an appointment with someone at the Microsoft store and they can make it work and install all new drivers. The only thing they won't do now once you cut it open is replace it
      • Either that or you can install linux on it from www.reddit.com/r/surfacelinux
      Ask FixBot
There is no going back but with some files and a drill bit you can make a sweet keychain fob that you can engrave with the CNC machine
4 other people completed this guide.
Hamish Davis
243 Reputation
1 Guide authored
2 Guide Comments
While this will make a tidy hole, the fact that you can't guarantee shavings won't fall into the chassis makes this riskier than a busted screen. Replacing the motherboard or battery are expensive by themselves, but a shaving that gets lodged into the battery is a fire risk, and lipo batteries aren't known for calm fires
Joshua Newman - Reply Share
I love this, I think this may be a viable method for replacing batteries in smartphones that are still good but not worth the careful dance around the glued touchscreens. And phones are typically carried in a protective case anyway!
Andrzej Rusztowicz - Reply Share
Past 24 Hours: 5
Past 7 Days: 41
Past 30 Days: 190
All Time: 8,324
