Up to 20% off select tools
Microsoft Surface Pro 2 SSD Replacement
Views: 103K
View statistics:
Past 24 Hours:
10
Past 7 Days:
56
Past 30 Days:
252
All Time:
103,436
Comments: 22
9 comments on steps, 13 guide comments.
Go to guide comments
Completed: 24
24 people have marked this guide "completed." Will you be next?
Favorites: 15
15 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 1 - 2 hours
Difficulty: Very difficult
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Needs More Images
A few more images would make this guide's procedures crystal clear.
Community-Contributed Guide
Better Introduction
Improve this guide by completing or revising its introduction.
Parts
Tools
    1. Microsoft Surface Pro 2 SSD Replacement, SSD: step 1, image 1 of 3 Microsoft Surface Pro 2 SSD Replacement, SSD: step 1, image 2 of 3 Microsoft Surface Pro 2 SSD Replacement, SSD: step 1, image 3 of 3
      • Remove the two T5 Torx screws, then take off the kickstand.
      Ask FixBot
    2. Microsoft Surface Pro 2 SSD Replacement: step 2, image 1 of 3 Microsoft Surface Pro 2 SSD Replacement: step 2, image 2 of 3 Microsoft Surface Pro 2 SSD Replacement: step 2, image 3 of 3
      • Use an iOpener or heat gun to melt the adhesive.
      • Insert 21 opening picks under the display.
      • Slowly lift off the display.
      Ask FixBot
    3. Microsoft Surface Pro 2 SSD Replacement: step 3, image 1 of 3 Microsoft Surface Pro 2 SSD Replacement: step 3, image 2 of 3 Microsoft Surface Pro 2 SSD Replacement: step 3, image 3 of 3
      • Remove the four ribbon cables connecting to the motherboard with a spudger.
      • Remove the 52 screws securing the motherboard to the metal plates and the plastic bezel.
      • Lift off the motherboard.
      Ask FixBot
    4. Microsoft Surface Pro 2 SSD Replacement: step 4, image 1 of 1
      • Unscrew the two screws on the mSATA SSD and remove the SSD. (Note: This image is from a first generation Surface Pro, but it works)
      Ask FixBot
24 other people completed this guide.
Author
with
Ronnie
3,860 Reputation
5 Guides authored
13 Guide Comments
How do you glue the back on? It looks like the adhesive that holds it on is messed up bad when it's removed.
Nate Barnes - Reply Share
Hi Nate,
Have you figured this out? I was wondering the same thing.
Adi V - Reply Share
You have to use double sided tape for electronics. They sell it on amazon. Use 5mm or wider to make sure the screen doesn’t fall out. Heat after application to make sure the glue sets properly.
Aaron Payer - Reply Share
Wow, I have been contemplating one of these but after seeing that picture with the heat gun, it looks like you might as well consider it a sealed box.
Mark T - Reply Share
Screen came off just fine using a hair dryer, but my Surface Pro 2 differs from these directions. Specifically, I got stuck not being able to remove the bezel because I don't have a T2 bit. My bezel screws are 5 x T5, 14 x T3, and 4 x T2. That doesn't match the photo shown here in step 3.
Boyd Patterson - Reply Share
Past 24 Hours: 10
Past 7 Days: 56
Past 30 Days: 252
All Time: 103,436
