Up to 20% off select tools
Microsoft Surface Pro 11 Screen Replacement
Views: 6K
View statistics:
Past 24 Hours:
12
Past 7 Days:
76
Past 30 Days:
410
All Time:
5,964
Comments: 0
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 30 minutes - 1 hour
Difficulty: Moderate
Featured Guide
This guide has been found to be exceptionally cool by the iFixit staff.
Fix Kits
These kits contain all the parts and tools needed to complete this guide.
Parts
Tools
Introduction
Go to step 1 ↓
Follow this guide to replace a broken, cracked, or non-responsive screen on your Microsoft Surface Pro 11.
You'll need replacement screen adhesive to complete this repair.
Note: Surface Pro 11 replacement parts differ depending on whether your device has an LCD or OLED screen. Before purchasing parts and consumables, make sure you know which type of screen your device has so you can select the correct parts for your repair.
    1. Microsoft Surface Pro 11 Screen Replacement, Before you begin: step 1, image 1 of 3 Microsoft Surface Pro 11 Screen Replacement, Before you begin: step 1, image 2 of 3 Microsoft Surface Pro 11 Screen Replacement, Before you begin: step 1, image 3 of 3
      • Before starting this repair, allow your Surface Pro's battery to drain below 25%. A charged battery may catch fire if damaged.
      • Unplug all cables and fully shut down your tablet.
      Ask FixBot
    1. Microsoft Surface Pro 11 Screen Replacement, Open the kickstand: step 2, image 1 of 3 Microsoft Surface Pro 11 Screen Replacement, Open the kickstand: step 2, image 2 of 3 Microsoft Surface Pro 11 Screen Replacement, Open the kickstand: step 2, image 3 of 3
      • Lay your Surface Pro screen side down and open the kickstand to about a 90‑degree angle.
      Ask FixBot
    1. Microsoft Surface Pro 11 Screen Replacement, Remove the SSD door: step 3, image 1 of 3 Microsoft Surface Pro 11 Screen Replacement, Remove the SSD door: step 3, image 2 of 3 Microsoft Surface Pro 11 Screen Replacement, Remove the SSD door: step 3, image 3 of 3
      • Use your finger to firmly press down on the SSD door indent until the door pops up.
      • Remove the SSD door.
      Ask FixBot
    1. Microsoft Surface Pro 11 Screen Replacement, Remove the SSD screw: step 4, image 1 of 2 Microsoft Surface Pro 11 Screen Replacement, Remove the SSD screw: step 4, image 2 of 2
      • Use a Torx Plus 3IP screwdriver to remove the 2.4 mm‑long screw securing the SSD.
      • Removing the SSD also functions as a battery disconnect and should be done before all major repairs.
      Ask FixBot
    2. Microsoft Surface Pro 11 Screen Replacement, Remove the SSD: step 5, image 1 of 3 Microsoft Surface Pro 11 Screen Replacement, Remove the SSD: step 5, image 2 of 3 Microsoft Surface Pro 11 Screen Replacement, Remove the SSD: step 5, image 3 of 3
      • Don't pull up at a sharp angle, or you may damage the SSD and its socket.
      • Use the flat end of a spudger to gently lift the notched edge of the SSD enough that you can grip the bottom corners with your fingers.
      • Use your fingers or tweezers to pull the SSD straight out of its socket and remove it.
      • During reassembly, getting the SSD fully inserted in its socket can be tricky. If you're having trouble, hold the SSD in place and use the flat end of a spudger to push on the notched edge.
      Ask FixBot
    1. Microsoft Surface Pro 11 Screen Replacement, Adhesive information: step 6, image 1 of 3 Microsoft Surface Pro 11 Screen Replacement, Adhesive information: step 6, image 2 of 3 Microsoft Surface Pro 11 Screen Replacement, Adhesive information: step 6, image 3 of 3
      • When separating the screen from the frame, don't insert your tool more than the following measurements on the given edges. Otherwise, you may damage your device's internals.
      • 2 mm on the left, right, and bottom edges
      • Don't insert your tool at all near the front facing camera on the top edge
      • 8 mm along the top edge (everywhere besides the front facing camera area)
      Ask FixBot
    2. Microsoft Surface Pro 11 Screen Replacement, Heat the right edge: step 7, image 1 of 1
      • Mild adhesive secures the perimeter of the screen to the frame. Heating the screen will soften the adhesive, making it easier to separate.
      • Heat an iOpener and lay it on the right edge of the screen for two minutes to soften the adhesive.
      • Alternatively, you can use a hair dryer or heat gun. But be careful, as the screen and battery are susceptible to heat damage.
      Ask FixBot
    3. Microsoft Surface Pro 11 Screen Replacement, Separate the right edge adhesive: step 8, image 1 of 3 Microsoft Surface Pro 11 Screen Replacement, Separate the right edge adhesive: step 8, image 2 of 3 Microsoft Surface Pro 11 Screen Replacement, Separate the right edge adhesive: step 8, image 3 of 3
      • Remember not to insert your pick more than 2 mm on the right edge.
      • Insert the tip of an opening pick under the screen near the bottom of the right speaker cutout.
      • Slide your pick towards the bottom edge and slightly rotate it so the tip goes under the notch in the screen.
      Ask FixBot
    4. Microsoft Surface Pro 11 Screen Replacement: step 9, image 1 of 3 Microsoft Surface Pro 11 Screen Replacement: step 9, image 2 of 3 Microsoft Surface Pro 11 Screen Replacement: step 9, image 3 of 3
      • Slide your pick down the right edge to separate the adhesive securing it.
      • Leave your pick inserted under the bottom right corner to prevent the adhesive from re‑sealing.
      Ask FixBot
    5. Microsoft Surface Pro 11 Screen Replacement, Heat the bottom edge: step 10, image 1 of 1
      Ask FixBot
    6. Microsoft Surface Pro 11 Screen Replacement, Separate the bottom edge adhesive: step 11, image 1 of 3 Microsoft Surface Pro 11 Screen Replacement, Separate the bottom edge adhesive: step 11, image 2 of 3 Microsoft Surface Pro 11 Screen Replacement, Separate the bottom edge adhesive: step 11, image 3 of 3
      • Remember not to insert your pick more than 2 mm on the bottom edge.
      • Insert a second pick under the bottom right corner of the screen and slide it along the bottom edge to separate the adhesive.
      • Leave your second pick inserted under the bottom left corner to prevent the adhesive from re‑sealing.
      Ask FixBot
    7. Microsoft Surface Pro 11 Screen Replacement, Heat the left edge: step 12, image 1 of 1
      Ask FixBot
    8. Microsoft Surface Pro 11 Screen Replacement, Separate the left edge adhesive: step 13, image 1 of 3 Microsoft Surface Pro 11 Screen Replacement, Separate the left edge adhesive: step 13, image 2 of 3 Microsoft Surface Pro 11 Screen Replacement, Separate the left edge adhesive: step 13, image 3 of 3
      • Insert a third pick under the bottom left corner of the screen and slide it up the left edge, stopping when you get to the bottom of the left speaker cutout.
      • Leave the pick inserted under the screen to prevent the adhesive from re-sealing.
      Ask FixBot
    9. Microsoft Surface Pro 11 Screen Replacement, Heat the top edge: step 14, image 1 of 1
      Ask FixBot
    10. Microsoft Surface Pro 11 Screen Replacement: step 15, image 1 of 3 Microsoft Surface Pro 11 Screen Replacement: step 15, image 2 of 3 Microsoft Surface Pro 11 Screen Replacement: step 15, image 3 of 3
      • Insert a fourth pick under the screen near the top of the left speaker cutout.
      • Slide your pick towards the top edge and slightly rotate it so the tip goes under the notch in the screen.
      Ask FixBot
    11. Microsoft Surface Pro 11 Screen Replacement, Separate the top edge adhesive: step 16, image 1 of 3 Microsoft Surface Pro 11 Screen Replacement, Separate the top edge adhesive: step 16, image 2 of 3 Microsoft Surface Pro 11 Screen Replacement, Separate the top edge adhesive: step 16, image 3 of 3
      • Remember not to insert your pick more than 8 mm on the top edge.
      • Slide the pick along the top edge and stop before you get to the front facing camera.
      Ask FixBot
    12. Microsoft Surface Pro 11 Screen Replacement: step 17, image 1 of 3 Microsoft Surface Pro 11 Screen Replacement: step 17, image 2 of 3 Microsoft Surface Pro 11 Screen Replacement: step 17, image 3 of 3
      • Be very careful not to touch the front facing camera lens with your tool.
      • Remove the pick enough that it can pass above the front facing camera.
      • Slide the pick along the top edge until it's past the camera.
      Ask FixBot
    13. Microsoft Surface Pro 11 Screen Replacement: step 18, image 1 of 3 Microsoft Surface Pro 11 Screen Replacement: step 18, image 2 of 3 Microsoft Surface Pro 11 Screen Replacement: step 18, image 3 of 3
      • Insert your pick 8 mm under the screen and slide it to the top right corner to separate the remaining adhesive.
      Ask FixBot
    14. Microsoft Surface Pro 11 Screen Replacement, Separate the screen: step 19, image 1 of 3 Microsoft Surface Pro 11 Screen Replacement, Separate the screen: step 19, image 2 of 3 Microsoft Surface Pro 11 Screen Replacement, Separate the screen: step 19, image 3 of 3
      • Insert the flat edge of two picks under the screen, below the two speaker cutouts.
      • Use the picks to gently pry up the screen, fully separating it from the frame.
      • Don't try to remove the screen yet, as a ribbon cable still connects it to your device.
      • If the screen feels stuck anywhere, use your pick to separate the adhesive in that area. Remember not to insert your pick too far under the screen.
      Ask FixBot
    15. Microsoft Surface Pro 11 Screen Replacement, Flip the screen over: step 20, image 1 of 3 Microsoft Surface Pro 11 Screen Replacement, Flip the screen over: step 20, image 2 of 3 Microsoft Surface Pro 11 Screen Replacement, Flip the screen over: step 20, image 3 of 3
      • Once the screen is fully separated, flip the top edge over the bottom edge and lay the screen down flat, being careful not to strain the ribbon cable.
      Ask FixBot
    16. Microsoft Surface Pro 11 Screen Replacement, Remove the screen cable shield: step 21, image 1 of 3 Microsoft Surface Pro 11 Screen Replacement, Remove the screen cable shield: step 21, image 2 of 3 Microsoft Surface Pro 11 Screen Replacement, Remove the screen cable shield: step 21, image 3 of 3
      • Use the tip of a spudger to lift the conductive tape off the copper shield, near the center of your device.
      Ask FixBot
    17. Microsoft Surface Pro 11 Screen Replacement: step 22, image 1 of 3 Microsoft Surface Pro 11 Screen Replacement: step 22, image 2 of 3 Microsoft Surface Pro 11 Screen Replacement: step 22, image 3 of 3
      • Insert an arm of a pair of angled tweezers in one of the gaps on the edge of the screen cable shield.
      • Use your tweezers to gently pry up and remove the shield.
      • Try to deform the shield as little as possible—you'll reuse it during reassembly.
      Ask FixBot
    18. Microsoft Surface Pro 11 Screen Replacement, Disconnect the screen: step 23, image 1 of 3 Microsoft Surface Pro 11 Screen Replacement, Disconnect the screen: step 23, image 2 of 3 Microsoft Surface Pro 11 Screen Replacement, Disconnect the screen: step 23, image 3 of 3
      • Insert the flat end of a spudger under the notched corner of the screen cable press connector and pry up to disconnect it.
      Ask FixBot
    19. Microsoft Surface Pro 11 Screen Replacement, Remove the screen: step 24, image 1 of 1
      • Grip the screen with both hands and remove it.
      • During reassembly, follow this guide to replace the screen adhesive and install your screen.
      Ask FixBot
2 other people completed this guide.
Author
with
Spencer Day
210,928 Reputation
1,265 Guides authored
iFixit Member of iFixit
Staff
119 Members
72,966 Guides authored
0 Guide Comments
Past 24 Hours: 12
Past 7 Days: 76
Past 30 Days: 410
All Time: 5,964
