Up to 20% off select tools
Microsoft Surface Pro 11 SSD Replacement
Views: 9.2K
View statistics:
Past 24 Hours:
15
Past 7 Days:
112
Past 30 Days:
493
All Time:
9,249
Comments: 0
Go to guide comments
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 5 minutes
Difficulty: Moderate
Featured Guide
This guide has been found to be exceptionally cool by the iFixit staff.
Tools
Introduction
Go to step 1 ↓
Follow this guide to replace or upgrade the SSD in your Microsoft Surface Pro 11.
Before starting this repair, read through Microsoft's guide on best practices for SSD removal. If your replacement SSD has data on it, make a backup of the drive before installing it.
    1. Microsoft Surface Pro 11 SSD Replacement, Before you begin: step 1, image 1 of 3 Microsoft Surface Pro 11 SSD Replacement, Before you begin: step 1, image 2 of 3 Microsoft Surface Pro 11 SSD Replacement, Before you begin: step 1, image 3 of 3
      • Before starting this repair, allow your Surface Pro's battery to drain below 25%. A charged battery may catch fire if damaged.
      • Unplug all cables and fully shut down your tablet.
      Ask FixBot
    1. Microsoft Surface Pro 11 SSD Replacement, Open the kickstand: step 2, image 1 of 3 Microsoft Surface Pro 11 SSD Replacement, Open the kickstand: step 2, image 2 of 3 Microsoft Surface Pro 11 SSD Replacement, Open the kickstand: step 2, image 3 of 3
      • Lay your Surface Pro screen side down and open the kickstand to about a 90‑degree angle.
      Ask FixBot
    1. Microsoft Surface Pro 11 SSD Replacement, Remove the SSD door: step 3, image 1 of 3 Microsoft Surface Pro 11 SSD Replacement, Remove the SSD door: step 3, image 2 of 3 Microsoft Surface Pro 11 SSD Replacement, Remove the SSD door: step 3, image 3 of 3
      • Use your finger to firmly press down on the SSD door indent until the door pops up.
      • Remove the SSD door.
      Ask FixBot
    1. Microsoft Surface Pro 11 SSD Replacement, Remove the SSD screw: step 4, image 1 of 2 Microsoft Surface Pro 11 SSD Replacement, Remove the SSD screw: step 4, image 2 of 2
      • Use a Torx Plus 3IP screwdriver to remove the 2.4 mm‑long screw securing the SSD.
      • Removing the SSD also functions as a battery disconnect and should be done before all major repairs.
      Ask FixBot
    2. Microsoft Surface Pro 11 SSD Replacement, Remove the SSD: step 5, image 1 of 3 Microsoft Surface Pro 11 SSD Replacement, Remove the SSD: step 5, image 2 of 3 Microsoft Surface Pro 11 SSD Replacement, Remove the SSD: step 5, image 3 of 3
      • Don't pull up at a sharp angle, or you may damage the SSD and its socket.
      • Use the flat end of a spudger to gently lift the notched edge of the SSD enough that you can grip the bottom corners with your fingers.
      • Use your fingers or tweezers to pull the SSD straight out of its socket and remove it.
      • During reassembly, getting the SSD fully inserted in its socket can be tricky. If you're having trouble, hold the SSD in place and use the flat end of a spudger to push on the notched edge.
      Ask FixBot
Once your laptop is reassembled, follow Microsoft's post SSD replacement guide.
3 other people completed this guide.
Author
with
Spencer Day
210,833 Reputation
1,265 Guides authored
iFixit Member of iFixit
Staff
119 Members
72,966 Guides authored
0 Guide Comments
Past 24 Hours: 15
Past 7 Days: 112
Past 30 Days: 493
All Time: 9,249
