This teardown is not a repair guide. To repair your Microsoft Surface Pro 11, use our service manual.
  1. Microsoft Surface Pro 11 Chip ID, Main Board Side 1: step 1, image 1 of 2 Microsoft Surface Pro 11 Chip ID, Main Board Side 1: step 1, image 2 of 2
    • Qualcomm X1P-64-100-103 Snapdragon X Plus deca-core applications processor
    • SK hynix H58G56BK8BX068 4 GB LPDDR5X SDRAM Memory
    • Qualcomm PMC8380-001-00 power management
    • Qualcomm PMC8380VE-001 power management
    • Qualcomm PMC1010H-001-07 charge pump & buck regulator
    • Qualcomm PMC1010H-001-08 charge pump & buck regulator
    • Qualcomm power management
    Ask FixBot
  2. Microsoft Surface Pro 11 Chip ID: step 2, image 1 of 1
    • Qualcomm SMB2360-002 battery charger
    • Qualcomm SMB2361-002 battery charger
    • Likely Qualcomm clock generator
    • Parade Technologies PS8830 USB4, DisplayPort 2.0, and Thunderbolt 3.0 retimer
    • Murata PE23108 LED backlight driver
    • Qualcomm audio amplifier
    • Analog Devices MAX34417 current & voltage monitor
    Ask FixBot
  3. Microsoft Surface Pro 11 Chip ID: step 3, image 1 of 1
    • Monolithic Power Systems MP2322 1 A synchronous step-down converter
    • Richtek RT5753ALGQW 3 A synchronous step-down converter
    • Monolithic Power Systems DC-DC converter
    • Nexperia 74LVC2G66 dual SPST analog switch
    • Texas Instruments TPS22964C 3 A load switch
    • Diodes Incorporated AP22653FDZ-7 adjustable current-limited power distribution switch
    Ask FixBot
  4. Microsoft Surface Pro 11 Chip ID: step 4, image 1 of 1
    • NXP Semiconductors NX3P1108UK high-side power switch
    • Toshiba TCR3UM18A 300 mA / 1.8 V LDO regulator
    • Texas Instruments SN74LV1T08 single 2-input AND gate
    • Diodes Incorporated 74AUP1G08FS3 single 2-input AND gate
    Ask FixBot
  5. Microsoft Surface Pro 11 Chip ID, Main Board Side 1 - Connectivity: step 5, image 1 of 1
    • Qualcomm WCN7851-501 FastConnect 7800 WiFi 7 & Bluetooth 5.4 controller
    • Qualcomm 2.4 GHz front-end module
    • Qualcomm 5 GHz front-end module
    Ask FixBot
  6. Microsoft Surface Pro 11 Chip ID, Main Board Side 1 - Filters: step 6, image 1 of 1
    • Qualcomm B7530 Bluetooth/WLAN SAW filter
    Ask FixBot
  7. Microsoft Surface Pro 11 Chip ID, Main Board Side 2: step 7, image 1 of 2 Microsoft Surface Pro 11 Chip ID, Main Board Side 2: step 7, image 2 of 2
    • NXP Semiconductors MIMXRT633SFFOB 32-bit ARM Cortex-M33 microcontroller w/ Xtensa HiFi4 audio DSP
    • Winbond W25Q512NW 64 MB serial NOR flash memory
    • Macronix MX25U1633FZUI 2 MB serial NOR flash memory
    • Renesas mixed signal array
    • Likely Qualcomm camera power management
    • NXP Semiconductors NX20P0407UK USB type-C port protector
    • Analog Devices MAX4983EEVB+ USB 2.0 DPDT analog switch
    Ask FixBot
  8. Microsoft Surface Pro 11 Chip ID: step 8, image 1 of 1
    • Vishay DG2723 dual SPDT analog switch
    • onsemi FPF2495CUCX 28 V over-voltage & over-current protection load switch
    • Diodes Incorporated AP22800HB-7 programmable load switch
    Ask FixBot
  9. Microsoft Surface Pro 11 Chip ID: step 9, image 1 of 1
    • NXP Semiconductors PCA9306 2-bit voltage-level translator
    • Nexperia 74AVC2T245 2-bit level shifter
    • Nexperia 74LV1T08GX single 2-input AND gate
    Ask FixBot
  10. Microsoft Surface Pro 11 Chip ID, Main Board Side 2 - Sensors: step 10, image 1 of 1
    • STMicroelectronics LSM6DSO 6-axis accelerometer & gyroscope
    • STMicroelectronics LIS2DW12 3-axis accelerometer
    • MEMSIC MMC5633NJL 3-axis magnetometer
    Ask FixBot
0 Guide Comments
Past 24 Hours: 8
Past 7 Days: 74
Past 30 Days: 230
All Time: 9,621
