Microsoft Surface Pen Tip Replacement
    1. Microsoft Surface Pen Tip Replacement, Tip: step 1, image 1 of 3 Microsoft Surface Pen Tip Replacement, Tip: step 1, image 2 of 3 Microsoft Surface Pen Tip Replacement, Tip: step 1, image 3 of 3
      • Order the Microsoft Surface Pen tip replacement kit.
      • Hold your pen at an angle and unscrew the top part of the pen.
      Ask FixBot
    2. Microsoft Surface Pen Tip Replacement: step 2, image 1 of 3 Microsoft Surface Pen Tip Replacement: step 2, image 2 of 3 Microsoft Surface Pen Tip Replacement: step 2, image 3 of 3
      • Extract the tip now that it is fully exposed.
      • When you extract the tip, make sure don't do it too hard. The inside of the pen can be broken.
      Ask FixBot
    3. Microsoft Surface Pen Tip Replacement: step 3, image 1 of 3 Microsoft Surface Pen Tip Replacement: step 3, image 2 of 3 Microsoft Surface Pen Tip Replacement: step 3, image 3 of 3
      • After you extract the tip, roll the tissue on toothpick.
      • I recommend cutting the tissue in half.
      Ask FixBot
    4. Microsoft Surface Pen Tip Replacement: step 4, image 1 of 3 Microsoft Surface Pen Tip Replacement: step 4, image 2 of 3 Microsoft Surface Pen Tip Replacement: step 4, image 3 of 3
      • Clean the inside of the top detachable part of the pen with a toothpick covered with tissue.
      • Make sure there is no residue on the edge.
      Ask FixBot
    5. Microsoft Surface Pen Tip Replacement: step 5, image 1 of 3 Microsoft Surface Pen Tip Replacement: step 5, image 2 of 3 Microsoft Surface Pen Tip Replacement: step 5, image 3 of 3
      • Choose the tip that you would like to use and insert in a hole.
      Ask FixBot
    6. Microsoft Surface Pen Tip Replacement: step 6, image 1 of 3 Microsoft Surface Pen Tip Replacement: step 6, image 2 of 3 Microsoft Surface Pen Tip Replacement: step 6, image 3 of 3
      • Screw the detachable part of the pen back on.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 15
Past 30 Days: 68
All Time: 7,492
