Introduction
Use this guide to remove or replace the upper case of a Microsoft Surface Laptop 3 (15").
Removing the SSD functions as a battery disconnect and should be performed before all major repairs.
Flip the laptop over and place it on your work surface, feet facing up.
Each foot has a hidden indent that will simplify removal.
To make sure the spudger is in the indent, insert it at the nearest long edge, pushing parallel to the short edges of the laptop, as shown.
Insert the pointed end of a spudger underneath one of the two rear feet, at its rear edge.
Push the spudger underneath the foot and pry up to release it.
Repeat to remove the second rear foot.
Insert the pointed end of a spudger underneath one of the two front feet, at its front edge.
Repeat to remove the second front foot.
Note that the front and rear feet are different.
Note that the front feet are directional and only clip in one way.
Peel a pad away from its backing, align it over a foot cavity, and press to secure.
Tool used on this step:Magnetic Project Mat$19.95
Use a T5 Torx driver to remove the four 3Â mm screws in the foot cavities securing the upper case to the device.
Grip the top edge of upper case above the keyboard and lift straight up to release it.
Lift the front edge of the upper case up and away from the laptop, taking care to not strain the keyboard and touchpad ribbon cable underneath.
Insert the flat end of a spudger underneath one edge of the ribbon cable connector, and pry up to release it.
Remove the ribbon cable from the motherboard.
Remove the upper case.
Set the upper case onto a clean surface, keyboard-side down.
Use a T5 Torx driver to remove the 2.7Â mm screw securing the SSD.
Grip the end of the SSD and pull it away from its board connector to remove it.
Repair didn’t go as planned? Try some basic troubleshooting or search our Answers community for help.
7 other people completed this guide.
3 Guide Comments
whats the max size ssd i can replace my 256gb with here please - as a 1tb at the very least would be perfect - as i do a lot of photoshop work here ..
with major major thanks in advance, j
This may be too late for you but may help others. The Surface Laptop 3 (15") can take 256gb, 512gb, and 1tb SSDs that iFixit sells. I read somewhere you should replace it with only the size your laptop originally came with. Not sure if it's somehow locked in firmware to prevent upgrading to a bigger SSD.
Did you upgrade yours to 1TB. If so, did it work?
Did you have to copy the OS (Microsoft Windows) to the new SSD? I think that's required to make it work.
Very pleased with the redesign of these units, much easier to repiar.
