Microsoft Surface Laptop 3 13.5" LCD Assembly Replacement
  1. Microsoft Surface Laptop 3 13.5" LCD Assembly Replacement, LCD Assembly: step 1, image 1 of 1
    • It's far easier than any other Surface device.
    Ask FixBot
  2. Microsoft Surface Laptop 3 13.5" LCD Assembly Replacement: step 2, image 1 of 1
    • From the bottom, carefully pry up the rubber feet on all 4 corners.
    Ask FixBot
  3. Microsoft Surface Laptop 3 13.5" LCD Assembly Replacement: step 3, image 1 of 1
    • Using a T5 screwdriver remove the 4 screws on each corner.
    Ask FixBot
  4. Microsoft Surface Laptop 3 13.5" LCD Assembly Replacement: step 4, image 1 of 1
    • Make sure the device is completely turned off before proceeding.
    Ask FixBot
  5. Microsoft Surface Laptop 3 13.5" LCD Assembly Replacement: step 5, image 1 of 1
    • With the screen open, lift the keyboard out. It doesn't take much force as the part is only held in with magnets once the screws are removed.
    Ask FixBot
  6. Microsoft Surface Laptop 3 13.5" LCD Assembly Replacement: step 6, image 1 of 2 Microsoft Surface Laptop 3 13.5" LCD Assembly Replacement: step 6, image 2 of 2
    • Invert the keyboard on itself and remove the unshielded keyboard assembly connector.
    Ask FixBot
  7. Microsoft Surface Laptop 3 13.5" LCD Assembly Replacement: step 7, image 1 of 3 Microsoft Surface Laptop 3 13.5" LCD Assembly Replacement: step 7, image 2 of 3 Microsoft Surface Laptop 3 13.5" LCD Assembly Replacement: step 7, image 3 of 3
    • Remove the clip-on shields for the display assembly.
    Ask FixBot
  8. Microsoft Surface Laptop 3 13.5" LCD Assembly Replacement: step 8, image 1 of 1
    • Unclip the connectors. They are pretty tight so I'd suggest using a spudger or 2.
    Ask FixBot
  9. Microsoft Surface Laptop 3 13.5" LCD Assembly Replacement: step 9, image 1 of 2 Microsoft Surface Laptop 3 13.5" LCD Assembly Replacement: step 9, image 2 of 2
    • Using a T6 screwdriver, remove the 6 screws holding in the display.
    Ask FixBot
  10. Microsoft Surface Laptop 3 13.5" LCD Assembly Replacement: step 10, image 1 of 2 Microsoft Surface Laptop 3 13.5" LCD Assembly Replacement: step 10, image 2 of 2
    • Lay the display on a heating pad being careful of the connectors. A heat gun would work too.
    • I used 60 Degrees C for around 15 minutes.
    Ask FixBot
  11. Microsoft Surface Laptop 3 13.5" LCD Assembly Replacement: step 11, image 1 of 2 Microsoft Surface Laptop 3 13.5" LCD Assembly Replacement: step 11, image 2 of 2
    Tool used on this step:
    Plastic Cards
    $2.99
    Buy
    • Use a metal card to get in between the glass and the housing. Swap to a plastic card to cut through the rest of the adhesive.
    Ask FixBot
  12. Microsoft Surface Laptop 3 13.5" LCD Assembly Replacement: step 12, image 1 of 1
    • Watch out for the Sensors up the top. If you damage these the device will fail to turn on. It basically bricks completely without the sensors.
    Ask FixBot
  13. Microsoft Surface Laptop 3 13.5" LCD Assembly Replacement: step 13, image 1 of 2 Microsoft Surface Laptop 3 13.5" LCD Assembly Replacement: step 13, image 2 of 2
    • Heat up the bottom of the display and horizontally pull the screen out. Try to leave the bottom adhesive intact as we are going to be using this later.
    Ask FixBot
  14. Microsoft Surface Laptop 3 13.5" LCD Assembly Replacement: step 14, image 1 of 3 Microsoft Surface Laptop 3 13.5" LCD Assembly Replacement: step 14, image 2 of 3 Microsoft Surface Laptop 3 13.5" LCD Assembly Replacement: step 14, image 3 of 3
    • Remove one side of the plastic bar holding the cables in place. Slide the display out leaving the plastic bar intact.
    Ask FixBot
  15. Microsoft Surface Laptop 3 13.5" LCD Assembly Replacement: step 15, image 1 of 1
    • Screen off. Time to move on.
    Ask FixBot
  16. Microsoft Surface Laptop 3 13.5" LCD Assembly Replacement: step 16, image 1 of 2 Microsoft Surface Laptop 3 13.5" LCD Assembly Replacement: step 16, image 2 of 2
    • Remove the snap-on shield and cable. We will need this later.
    Ask FixBot
  17. Microsoft Surface Laptop 3 13.5" LCD Assembly Replacement: step 17, image 1 of 2 Microsoft Surface Laptop 3 13.5" LCD Assembly Replacement: step 17, image 2 of 2
    • CAREFULLY loosen the sensor cable on the back of the display.
    Ask FixBot
  18. Microsoft Surface Laptop 3 13.5" LCD Assembly Replacement: step 18, image 1 of 3 Microsoft Surface Laptop 3 13.5" LCD Assembly Replacement: step 18, image 2 of 3 Microsoft Surface Laptop 3 13.5" LCD Assembly Replacement: step 18, image 3 of 3
    • Heat the area around the sensors from the front. The adhesive here isn't very strong so you don't need loads of heat.
    Ask FixBot
  19. Microsoft Surface Laptop 3 13.5" LCD Assembly Replacement: step 19, image 1 of 3 Microsoft Surface Laptop 3 13.5" LCD Assembly Replacement: step 19, image 2 of 3 Microsoft Surface Laptop 3 13.5" LCD Assembly Replacement: step 19, image 3 of 3
    • Remove the old adhesive and make sure it's clean. You really don't want to be removing this screen once it's set down.
    Ask FixBot
  20. Microsoft Surface Laptop 3 13.5" LCD Assembly Replacement: step 20, image 1 of 2 Microsoft Surface Laptop 3 13.5" LCD Assembly Replacement: step 20, image 2 of 2
    • Install the new adhesive. Remove any large clumps on the bottom. We left the old stuff down there as it's a bit awkward to get to cleaning and reapplying-wise.
    Ask FixBot
  21. Microsoft Surface Laptop 3 13.5" LCD Assembly Replacement: step 21, image 1 of 1
    • Test the new screen. Make sure you connect the sensors or it won't start or respond at all.
    Ask FixBot
  22. Microsoft Surface Laptop 3 13.5" LCD Assembly Replacement: step 22, image 1 of 2 Microsoft Surface Laptop 3 13.5" LCD Assembly Replacement: step 22, image 2 of 2
    • Slide the cable back under the plastic bar and set it back in place. Lightly pull the cables to make sure there's no slack internally.
    Ask FixBot
  23. Microsoft Surface Laptop 3 13.5" LCD Assembly Replacement: step 23, image 1 of 1
    • Remove the plastic layer on top of your adhesive and set the screen into the housing. You need to push the screen in quite a bit at the bottom to make it sit correctly.
    Ask FixBot
  24. Microsoft Surface Laptop 3 13.5" LCD Assembly Replacement: step 24, image 1 of 3 Microsoft Surface Laptop 3 13.5" LCD Assembly Replacement: step 24, image 2 of 3 Microsoft Surface Laptop 3 13.5" LCD Assembly Replacement: step 24, image 3 of 3
    • Place the assembly in then screw it in. Connect the cables and replace the shields.
    Ask FixBot
  25. Microsoft Surface Laptop 3 13.5" LCD Assembly Replacement: step 25, image 1 of 1
    • Install the screws and feet and you're done!
    Ask FixBot
Let me know how you got on. I think we can all agree this was much easier than a Book 1… lot less nerve-racking too.
9 other people completed this guide.
Eric
1,495 Reputation
1 Guide authored
SMASHED IT, Auckland Member of SMASHED IT, Auckland
Business
9 Members
4 Guides authored
2 Guide Comments
Real very helpful and very nicely explained
Praveen - Reply Share
Thanks Praveen
Eric - Reply Share
Past 24 Hours: 1
Past 7 Days: 26
Past 30 Days: 84
All Time: 11,242
